Blacksmith Shop
Update:
This is perhaps the most boring thread ever.
I'm still gathering info on my blacksmith shop attempt. I ordered a lil Chopper from NWSL. Chris Bohn got back with me on the shingles @ 15 bucks a sheet for cherry with 3m backing. They are fantastic shingles other than hand cut ones I also make. Chris had a run of O scale kits under Full Circle Models and he sold 90% of the business to Foggy Mountain Models.
One day soon I'll start. Looks like I'll be 3dp the windows and scratch building the doors. I want to keep the sizing accurate to what the manufacturer had in the kits.
Quote from: Philip on June 06, 2026, 07:34:52 AM
Quote from: PRR Modeler on June 06, 2026, 07:01:22 AMPhilip I believe that Tichy has them.
TY
I believe your wrong!  :)
I had them made laser cut Rail Scale Models.
Stephen did a hell of job making them for me.
Actually, I think it's been interesting to consider what constitutes an 'iconic' Blacksmith Shop, as well as to discuss what's available to model one.
I have 3 walls framed. Sorry for the picture quality. They are sitting on a glass plate.
One to go.
Howdy Philip, nice work framing the shop. What siding will you use?  Have fun, mike
Over the week-end I experimented with different approaches to making the framing true and square.
I'm use Aleene's tacky glue in a syringe.
I tried the taping wax paper backer over the drawing and you can't see where to exactly place the studs. The wax paper is very thick.
I tried packaging tape directly on the drawing as a backer and the studs just slide around.
I set the top plate first with a tiny drop of glue every other stud directly to the paper followed by gluing all the studs directly to the paper. I use a couple of tiny dots to keep the tiny stud in position after setting the top plate, then I eyeball the studs to make sure they are not twisted like Home Depot lumber. :o
Once everything is buttoned up and finished I carefully remove the backing paper plans. I usually have 200 or more areas where the paper stuck to the framing wood. I have found a warm dish rag will soften the blemishes and remove most of the excess glue and paper debris. I also use a toothpick and # 11 blade to remove the excess dry puddles of glue. The process takes at least a half hour of mind numbing work.
With that said, has anyone ever tried using onion paper or tracing paper over your plans?
Quote from: friscomike on June 15, 2026, 09:21:55 AMHowdy Philip, nice work framing the shop. What siding will you use?  Have fun, mike
Wood 1x8, 10's, 12's or whatever. I have a huge supply of coffee stirrers. Was looking at my scrap wood and I may have enough. Didn't order anything from NESL yet. I'm burning through 2x6 with the framing! Geeze!
Thanks for looking Mike!
The rafters have me worried. It may be a long row to hoe.
Nice way to start a Monday morning.  Philip in full swing!!
Looks great.
I just do the frame right to the paper.  It is a pain in the butt picking those little pieces of paper off the frame!!
Philip awesome framing job.
Philip great job on the framing!!! I've always used Cut-Rite waxed paper and have good results with it. It does stick a little but nothing a sharp #11 doesn't cure. Keep going this is going to be a great build.
Quote from: Jerry on June 15, 2026, 10:02:31 AMNice way to start a Monday morning.  Philip in full swing!!
Looks great.
Thanks Jerry!
Not sure about full swing. Like a rusty old gate swing.. ;D
What glue do you use?
Quote from: PRR Modeler on June 15, 2026, 10:04:58 AMPhilip awesome framing job.
Thanks Curt! What are you working on?
Quote from: Philip on June 15, 2026, 10:13:20 AM
Looks great.
Thanks Jerry!
I use Titebond wood glue.
Quote from: Larry C on June 15, 2026, 10:12:26 AMPhilip great job on the framing!!! I've always used Cut-Rite waxed paper and have good results with it. It does stick a little but nothing a sharp #11 doesn't cure. Keep going this is going to be a great build.
Thanks Larry! I did notice when using packing tape it made the glue crystal clear blobs..
I might try wax paper again.
Quote from: Jerry on June 15, 2026, 10:15:46 AM
Looks great.
I can't get it to bond fast enough. Lots of people swear by it. What is the secret?
Larry, what glue do you use?
Thanks Jerry!
