Blacksmith Shop
Some clearer wall images. More clean up needed. Digital camera on duty....
Philip,
I agree with the other folks here, about the framing, it's excellent!
My wife makes hand made cards, and has used parchment paper. Glue doesn't stick to it.
And I don't think your wood would slide around on its surface. Try it to see what
you think. I have yet to try it myself, so go lightly with it if you do.
A great mock-up would have been to use the paper plans, glued together..  ;D
rather than taking the time to construct all of that nice wood framing. ha!
Philip to answer your question, I use Elmers white glue and apply a tiny bit on each end on the outside frame piece with a toothpick. After the perimeter dries all the interior framing gets glued to that. This avoids a lot of glue marks on the framing. Hope that made sense.
Quote from: Pennman on June 15, 2026, 10:44:42 AMPhilip,
Thanks Rich! I altered the plans you shared a bit. I will give it a try! We use it all the time. I also think the used parchment from the oven would make perfect tattered and stained roll curtains. Olive oil is a perfect water stain after cooking.
Quote from: Larry C on June 15, 2026, 10:58:15 AMPhilip to answer your question, I use Elmers white glue and apply a tiny bit on each end on the outside frame piece with a toothpick. After the perimeter dries all the interior framing gets glued to that. This avoids a lot of glue marks on the framing. Hope that made sense.
Perfect! Thanks!
Philip I'm currently building a SW Shipyard at Foss Landing. I have a thread under kit building but nothing to show at this point.
Speaking of glue, I use WS Foam Tack Glue for all wood gluing and have for years.
Quote from: PRR Modeler on June 15, 2026, 12:36:10 PMPhilip I'm currently building a SW Shipyard at Foss Landing. I have a thread under kit building but nothing to show at this point.
Cool, I'll check the thread soon. I never tried the WS glue. Is it white when wet?
Neat building! SW Foss Landing Link
Philip white then clear.
Quote from: PRR Modeler on June 15, 2026, 06:33:43 PMPhilip white then clear.
Thanks!
Fourth wall is framed. Now to unstick the sticks after a overnight cure.
The gables are next. No plan yet.
Very nice job Philip.
Philip, nice job on the framing and even has the Jerry Seal of Approval.
Philip fantastic framing job!!! and it looks to be good sized. I'm sure you've already considered this, and depending how much you are going to detail the inside, please don't make the same mistake I made on my first Shop. Add the details to the walls BEFORE you glue the walls together; makes life so much easier.
Quote from: Jerry on June 15, 2026, 11:27:51 PMVery nice job Philip.
Thanks Jerry!
Quote from: Rick on June 16, 2026, 06:52:51 AMPhilip, nice job on the framing and even has the Jerry Seal of Approval.
I know! How did that happen? Thanks!  8)
Quote from: Larry C on June 16, 2026, 08:19:50 AMPhilip fantastic framing job!!! and it looks to be good sized. I'm sure you've already considered this, and depending how much you are going to detail the inside, please don't make the same mistake I made on my first Shop. Add the details to the walls BEFORE you glue the walls together; makes life so much easier.
Yes, I'm paying attention but sitting on the fence of why we do stuff and hide it with exterior boards and non removable roofs?
Thanks for looking!
Quote from: Philip on June 16, 2026, 09:05:57 AMYes, I'm paying attention but sitting on the fence of why we do stuff and hide it with exterior boards and non removable roofs?
Thanks for looking!
I'm with you on that front and that's what prompted me to add lights to my last Machine Shop so you could see the interior details. Not sure if you remember Karl Allison (UK Guy) from the old RR-Line Forum but he built a massive Machine Shop, 3 rails in I believe, and he went one step further and figured out a way to make the entire front wall removable (held in position with the details) so you could get a clear view of all his interior details.
Here's the link if you want to check out his techniques: https://sierrawestforum.discourse.group/t/the-loco-and-service-shops-scratchbuilt-in-o-scale-karl-a/265
You'll have to scroll down a ways to see his actual build; it's quite impressive.
