Quote from: Philip on July 26, 2026, 10:11:19 PMOh Fun! Looking good~
Mine had an older N 20 type motor.
Thanks Philip,
From what I can gather I believe the supplied motor has changed over the years.
Quote from: Rick on July 27, 2026, 06:09:22 AMRon, you're flying on this build.
Great color on those ties.
Thanks Rick,
I'm having a ton of fun building this and with 3 day weekends, it gives me lots of time to model.  Glad you like the colour on the ties.
Quote from: PRR Modeler on July 27, 2026, 06:54:24 AMWow Ron. You are smoking through this build. Everything looks very professionally done.
Thanks Curt,
Building this has been a blast.
Quote from: Larry C on July 27, 2026, 07:43:52 AMRon great work and attention to detail!! Looks like a winner to me.
Thanks Larry,
It's has been an easy build so far as the engineering is spot on with very little fitting or sanding required.
Quote from: Jerry on July 27, 2026, 11:25:35 AMGod there must be a loco on the the other side waiting to get out of the terminal.
At the rate your going he won't have to wait long!!!
Excellent build Ron.
Thanks Jerry,
The crew is working overtime to get this done as the yard crew almost lost one locomotive into the void forgetting that the original turntable went missing, the cause of which is still under investigation.
Howdy Ron,
The turntable is progressing well.  Thank you for taking the time to document the process.  It is outstanding.
Quote from: friscomike on July 28, 2026, 11:05:57 AMHowdy Ron,
Thanks Mike,
Glad you are enjoying the process.
Well my week at work is done and I have now time to get back to the turntable build. ;D  So without further ado, lets get to it.
I think from this point forward I'll show each step as I complete them instead of saving two or three steps and then posting them.  The reason for this is that I can post while I let the stain dry for the next step.
Part 8 - Bridge Support Wheel Assemblies
First step is to stain the parts.  Shown here is the wheel support (at top) and the pieces required to build one wheel housing.
The sides and end of the wheel housing glued to the wheel support.
The wheel and axle installed in the wheel housing.
The axle capture plates installed.  These are a very snug fit so that the axle stays in place.
One completed wheel assembly.
The above steps were completed to complete the second wheel support assembly.
The bridge support wheel assemblies attached to the bridge.
On to the next step. . . . . .
Thanks Philip and Rick,
This is turning out to be a fun easy build.
Very nice although the wheel assembly looks very fiddly.
Quote from: PRR Modeler on July 31, 2026, 07:12:30 AMVery nice although the wheel assembly looks very fiddly.
Thanks Curt, actually the wheel assembly went surprisingly well, everything fit precisely.
Part 9 - Adding the Bridge Stringers
The instructions call for the stringers to be glued in place using one of the stay wires as a spacer, then turn everything upside down and weigh it down to keep it flat and square.  I figured this would be frustrating and complicated to keep square so I took a more measured approach.
I started by gluing the outer stringers to the outside of the bridge.  I clamped them in place making sure that the outside stringers were flush with the edge of the bridge.
I used some scrap wood and clamps to the center section of the bridge to make sure that the stringers were flush with the bridge deck.  This insures that the bridge will be flat when the glue dries.
The outer stringers glued to the deck.
I measured the diameter of the stay wires that were supplied with the kit.  The diameter of the stay wires were 0.032 diameter.  Rather than use the stay wire as the spacer, I didn't have any .030 styrene that was suitable so I cut some 0.010 and 1.020 sheet styrene in strips to use as spacers.
I then clamped the inside stringers to the outside stringers using the spacers.
