Building SRMW The Millett Creamery
Started by Vilius, May 14, 2015, 09:02:22 AM
Great build , love the brickwork and the colors, very convincing stuco.
Vilius
Thank you, Tom, Mark and Jan.
Since I had mix of plaster and urethane walls I sprayed them with gray automotive primer to get uniform surface. Then I painted brick patches. I will describe my method later. Then stucco. I used Suede craft paint by Craftsman (Michaels brand?). I am not sure if it comes that thick or mine just sat for too long but I had to dilute it with water and do two coats. After seeing paintbrush marks in the area where I tested undiluted paint I decided to try stippling the paint. It worked. The surface looked like smother version of stucco so I finished the rest of the building this way. Then I painted stone foundation with Dove Gray craft paint (I think it is available only in certain areas since I can't find it locally and it is still being produced. It was sent to me from Ohio along with a kit to build). Perhaps I could do the next step right away but I left the paint to dry for 24 hours. The next day I used two brown and one dark gray color somewhat diluted craft paints to do individual bricks. After it dried (10-15 min) I applied heavily diluted Dove Gray over the stones and set aside for another 24 hours. Then I applied my oil wash over entire structure. I didn't use any chalks. The wash is made of Turpenoid and oil paint. Mineral spirit can be used but Turpenoid is nearly odorless so I like it better. Some time ago I bought a box of Reeves oil paints. Included was tube Ivory Black. I used it for several years until I ran out of it. It wasn't pure black. It had some brown in it and I liked that aspect. After I ran out of it I got tube of Ivory Black for real artists. Unfortunately it turned out to be pure black oil paint. I had to get brown as well. I add them both in my mix now.
To be continued...
Vilius
Vilius
Bricks.
You can find info on how to do bricks right way in Karl Osolinski's thread on RR Forums here:
http://www.railroad-line.com/forum/topic.asp?TOPIC_ID=36835
Now how to paint bricks lazy man's way. First, I glue walls together with 5 min epoxy. Then apply masking tape on each side of joint leaving about 1/32-1/16 gap in between. I use lightweight spackle to fill the gaps and let it dry for a day. After removing the tape I sand, scribe and whatever it takes to make joint invisible. When I am done I take the building outside and lightly spray with white paint. I don't know if it is necessary but I let it dry for 24 hours. Then I paint the building with off white making sure I get it into all mortar lines. After I take different off white and /or light gray and randomly paint some areas. And again I let it sit for 24 hours. When I come back I use dark gray, brick, red, orange color craft paints and dry brush the brick in the order I have listed. Then I do the stones as I have described earlier, areas around windows and whatever is left. When all is done I apply my oil wash.
The brick can be colored using a sponge. I haven't tried it myself. I personally feel that dry brushing gives me more control.
I use my 2004 digital SLR to take my pictures. A sheet of white mat board is my background. I place one end against the wall and other on the floor then push the center to make curved V. I use two lights. One of them is 300W. The other is 200W. I place them at about 1 ft away from each corner of mat board facing towards and down the model. I am sure Wattage and light placement is wrong from pro photography point. I know I am supposed to use diffusers and perhaps third light but most of the time I get acceptable result and that is enough for me. The only time I use third light is when I am taking pictures of larger diorama and I use it to light the back. One of these days I may read a book about proper lighting technique...
Vilius
#18
Vilius,
THANK YOU for sharing your painting and building methods that you used for this build. I will print it out and save it in my work bench note binder.
Did not know you used an oil wash instead of the common achohol and india ink, A/I wash. Dove Grey is sold in the craft stores here . Let me know if you need any.
Tom ;)
Vilius
Great build and thread! Thanks for sharing your techniques with us - looks great.
Vilius,
Thanks for the painting tips and great explanation on how you do it.  Looking forward to more progress.
Vilius
Guys,
Thank you for stopping by. I am going to take a short break. It is summer time after all.
Vilius
Hi Vilius:
Looks just wonderful. Great paint and choice of colors.
UP Fan
Great work!  The whole building has a perfect grunge look to it.  Nice weathering.
Vilius
Thank you Karl and Bob.
After vacation and taking time off due to some tragic event I am building models again. Here is where I am at.
Vilius
Mike Engler
Vilius, this build is coming along very well. Not an easy project but you have been skillful as well as artful.
One of the big challenges working with a structure such as this is making the corners look like they match, and you have done a great job on yours. I'll follow along as you do the detailing.
mike.engler59@gmail.com
Vilius
Thank you, Mike. I agree. The corners are perhaps most challenging part of any plaster kit.
Vilius
Looking tremendous, Vilius!
Vilius
Vilius,
Great looking build ! What a difference with the rafters, roofing and dormers added on.  8)
