Lighting Bar Mills Sokol's Furniture and Mattress Company
Started by ReadingBob, November 27, 2015, 07:40:54 AM
Quote from: Slim Jerkins on December 28, 2015, 09:27:13 AM
Great job Bob!
How do you find the hollow tubing to be out of scale? From your pictures I can't tell much difference.
-slim
Thanks Slim!
To my eye it appeared to be a little bit thicker.  I'll have to search for the piece Tom gave me and compare the two.  I could be wrong.  Wouldn't be the first time.   ::)
I just realized that there was one minor thing I failed to mention.  The wire I have that leads out of the structure was just some leftover wire from a garage door opener.  In one of the photo's you can see where I soldered it directly to the copper tape.  I found that any tension on that wire (including the weight of the wire itself) was enough to start pulling the copper tape away from the base and risk a short.  To alleviate that problem I added a cross piece of 1/8" strip wood then attached that wire to the center of cross piece with a plastic wire tie.  Now the wire won't put any stress on the copper tape.   :D
And, for what it's worth, the final count was 40 LED's.   8)
Slim Jerkins
Quote from: ReadingBob on December 28, 2015, 10:37:27 AM
Be careful with solid core wire - since it's stiff it can do that. Another thing is that it can easily break if you nicked the wire while stripping it.
I usually have a mini hot melt gun close by for putting a little blob onto a wire connection to make it secure.
-slim
Quote from: Slim Jerkins on December 28, 2015, 11:28:38 AMI usually have a mini hot melt gun close by for putting a little blob onto a wire connection to make it secure.
Good tip!   :D  I thought about using 5 minute epoxy to do something similar.  The hot glue gun never crossed my mind.  Thanks!
Wow. I'd say this operation puts you just below Neurosurgeon and just above Ortho ( that's like building benchwork  ;) ).
Really great plan and execution!
Great build thread Bob. The lighting looks great and lots of good tips.  I really like the idea of having a soldering iron and a hot glue gun on the work bench at the same time. So how long will it take me to get burned?  Just kidding - a spot of hot glue at the right time sounds like a great idea.
I owe you big time now Butty! Sokol's will be a focal point on the A&S RR. Can't wait to see it.
Quote from: Cuse on December 28, 2015, 04:39:27 PM
Thanks John!  I didn't electrocute myself or burn down the structure so I consider it a success.   ;D
Quote from: S&S RR on December 28, 2015, 08:18:49 PM
Thanks John!  I only burned myself once with the soldering iron while working inside the building.  It was very, very minor though.   :D  I guess it's a good thing I didn't have the hot glue gun out.   ;D  ;D
Quote from: ACL1504 on December 29, 2015, 08:59:30 AM
Thanks Tom,
At the very least it'll be a focal point when the lights in the room are dim and it's all lit up!   8)   :D  ;D
I need to drop it off along with your copper tape and the DVD you lent me.  I'll check with you to see when you're going to be around.
donatode
-slim
