Quote from: ACL1504 on April 11, 2019, 11:16:30 AM
WOWSER!
Thanks for stopping by Tom. When you started your third level it gave me the bug to add on and put in the staging yard that I wanted. Okay, so I spent a little money on cabinets. All approved by the CFO.
Today, all of those cabinet boxes have been emptied and the cabinets are roughly in position. Here are a few progress pictures.  I'm currently reviewing what height I want the yard to be at, now that I plan on a second level in the future.  Long term planning, I don't expect to get to the second level for more than 10 years. I had the first cabinet out of the box as was about to move it in position when I remembered to take a, before picture. There is a lot of stuff in the picture that will not be there when this section of the layout is complete.
You can see the plywood for the table top stacked against the wall.
Here is a picture with the cabinets sitting with an inch or so of final position.  The L section of the sofa is out of place so I could get in to make adjustments.
If you page back in the thread to the plan view of the layout you can start to see how this is going to look when completed.
Finally, for today, the future location of the Langford Ovalix Version 2.0. This will get the trains from the 53.5 inch level from the other room - to the 52 inch level of the upper level and 42 inch level of the yard level of this section.
I look forward to seeing you're progress Dave. Do I understand correctly that on top of the cabinets will be a yard?
Quote from: PRR Modeler on April 12, 2019, 06:28:10 PM
Curt
Yes, this entire section of the layout will be a large yard. If you look back on page 155 of this thread I posted a track diagram.
Update: After getting started on the benchwork and seeing everything full scale I decided to move the turntable and roundhouse to the area by the window (top of the ovalix). This will allow me to utilize the yard real-estate better and turn longer trains on the Wye. Moving the roundhouse also fits in better with my plans for the upper level. I will post a new track diagram when I complete the CAD work. I'm sure glad I came up with this new design before I started laying track. ;)
EricQuebec
Hi John,
I'm still working on my own MacKenzie Milling co kit (I've bought the kit after you assemble it on your S&S RR, and be very impressive with it).
Actually I'm not sure how paint the Paddle wheel. Look like wood or rusted metal ... That's a dilemme.
What color have you used for it on your model ?
Thanks. Eric
Quote from: EricQuebec on April 13, 2019, 05:10:05 PM
Hi John,
Thanks. Eric
Hi Eric
I had to go back and look at my build to remember what I did.  I painted it for wood construction - started with a brown primer and then used chalks to whether it.  I used a lot of slim green and also added some pigeon poop. I took a couple pictures and wrote myself a note to go back and hit the metal parts (the bolt heads and the spindle) with some rust colored chalk. Every time I look at a build I find little things to improve it.  Here are the two pictures that I took for your reference.  I hope this helps.
EricQuebec
Quote from: S&S RR on April 13, 2019, 06:51:18 PM
Hi John,
Thanks. Eric
Hi Eric
It help a lot. Thank you very much my friend.
Eric.
