The popsicle stick in the above picture was another test of the painting technique.
For the details of the "wet brush technique"  see the Sierra West Scale Models Website or U-tube. Brett Gallant has a number of great techniques described in his "university" section of his website. If you can get a chance to attend one of his clinics - just do it!
Next step, was getting the casting ready for the paint booth. George's casting are so good that this doesn't take long.
This kit has a number of unique casting that gives the build that run down look.
The workbench - it didn't take very long for me to mess it up.
Here is the 1983 color add that George ran for this kit.
This kit was made before laser cutting so George cutout the window openings with a table saw. The final cut is up to the modeler in some cases and the wall sections have strategic cut lines that need to be pieced together.  I save all the little pieces from the openings for test samples for coloring the next kit. The pieces I used for samples on this kit came from the Brambell's build I did last year.
Here is how I left the walls at the end of the day - ready to test fit the window castings.
Today, I made some more progress on my Jacob's coal build, it is amazing how many pieces of strip wood go into each of the coal bins.
So the outside walls of the bin is made of individual boards? If so you're doing a even better job than I thought!
I complied a couple more steps on the Mackenzie build, yesterday.  First, I glued the wall sections together. With the "before lasers" kits the windows were cut with a table saw so the wall sections were in two or three pieces.
