You are going to be busy, but it looks like a lot of fun. You definitely have enough things to do over the winter.
Quote from: Dave K. on October 24, 2017, 06:10:54 AM
"Sellios Row" is going to be spectacular! 👍🏻
Dave
Thanks - George's kits are going to be well represented on my layout. I have been collecting them for 25 plus years.
Quote from: Cuse on October 24, 2017, 07:11:04 AM
That's going to be awesome!
I like your full-time job better than mine ;)
This is the best job I ever had. Long hours but I enjoy every minute of it.
Quote from: PRR Modeler on October 24, 2017, 09:47:31 AM
Hi Curt
Yes - I like to keep busy. Thanks for following along.
Raymo
Wow! That's quite the ambitious project you have ahead of your self.
There's a small fortune there in yellow boxes.   The 'million dollar spur' :-)
Quote from: Raymo on October 24, 2017, 10:40:09 AM
Yes, it's a big project. And I have 5 more areas this size and bigger waiting to get worked on.  I'm going to try to work up to PostalKarl speed.  That's faster than light speed.  The key is to maintain the quality. Karl does.
Quote from: deemery on October 24, 2017, 10:40:25 AM
Dave
You would be correct if I paid eBay prices.  I think I should call it the before eBay spur.  If you add up what I paid George for the kits it's about what it cost me to go see his layout.  It is worth every penny. I think I will add up the prices on the boxes, as I put them on the shelf in the order I plan to build them.
Today, was one of those days when I worked a little bit on about 6 different projects. It was just the way it worked out. I few more wall castings were added to the Locomotive Works.
I also made some progress with the Mackenzie build. The paddles were added to the waterwheel and it received a coat of paint.
The progress on the Mackenzie build is looking good. It's good to have a few projects to go back and forth on.
Good job.
Quote from: MAP on October 29, 2017, 07:04:46 AM
Looking good John.
Thanks Mark
I made some more progress today - I will post some pictures in a few minutes.
Quote from: PRR Modeler on October 29, 2017, 10:01:33 AM
Everything is looking good
Curt
Thanks - I'm trying to get Mackenzie's finished before I get the Fox Run out of the box.
