Baxter's Building Supply FSM JS-5
Started by postalkarl, July 09, 2017, 04:45:26 PM
fbernard65
Hi Karl,
From the pics, the rust seems a bit intense.  You may want to tone it down a bit if you can.
Frank
Gerald Mabry
Looking forward to following along.
Hi Gearld:
Glad to have you aboard.
Hi All:
Got A lot of pain in the neck work finished today. Kit calls for plywood but I used black Board with foam core.
Karl,
Looking great. The black foam board will certainly make the diorama much lighter.
Hi Tom:
Thanks buddy appreciate it. Yes much lighter and A lot easier to cut.
Hi All:
This will be going on the shelf for a few days as Doug asked me to build the new background kit Murdock Fasteners.
Hi Guys:
Got a little more work done on this one. Added the rest of the concrete trestle walls.
Hi All:
Got the rest of the trestle walls installed and my 2 gravel piles per the instructions. They are dark as they are not dry yet.
Hi Guys:
Scenery is finished between all the piers. Not dry yet but here's a photo.
How did you do the piles?  Is there a former underneath the gravel?
Hi Dave:
Yes there is a former under the gravel. It is A wet plaster mound. I put a scoop of wet spackling between the piers with a teaspoon and the shaped them with a popsicle stick. The the gravel was applied. After that Straight Rubbing alcohol was applied and then Woodland Scenics scenic cement was applied over that. Then A light dusting of more earth and other scenic materials.
Hi curt:
Appreciate the compliment.
