Winter Build Challenge: The Blue Slipper by KC's Workshop
Started by Dave K., January 20, 2018, 11:42:00 AM
Like John, I've done brick structures in various shades of red but this time would like to try and capture the limestone color of the prototype. While I get my thinker workin' on that I'll move on to the shed for the side of the building.
Here's Kenny's version as it appears on his Cameron St. Corner dio...
Dave
Thanks for the close-up pictures of the brick.  Solid color brick walls are actually more rare than the multi-color brick in this wall.  I'm trying to develop a technique to get the variation in HO brick. I can color individual bricks - which helps.  What I want to achieve is the bands of color within the brick like I get with hydrocal rock castings. I ordered some blank brick walls to do some experimenting.
I'll be following along. I didn't realize it was a brick structure until I looked closer. I think this one is another winner and has many possibilities.
We'll be watching as you develop a brick technique. For the shed/annex I braced the walls and then applied a light inkahol wash.
Next a super-light drybrushing using an off-white.
Like John, I kerp sheets of clapboard and laser-cut brick on which to do color ecpetiments. First I did a straight spray of rattle-can Sand.
Then, as I've done on red brick, I used the Fast-n-Final spackle technique for mortar. Hmmm...don't like it. I'll save this test piece and play with it some more later.
Experimented some more. Methinks I'm settling on Apple Barrel Sandstone with a few drops of Americana Buttermilk.
It actually has more of a yellow tinge to it than is apparent in this iPhone pic.
Tom has Diet Pepsi breaks...I'll pause for this public service announcement.
Coming along nicely!  I'll be taking notes on your coloring techniques.
Quote from: MAP on January 20, 2018, 05:38:37 PM
Uh oh! I'd better not screw it up! 🤬
I'm going with a khaki accent color. Used it on the shed corner trim, the two Tichy windows, and the laser board door, which I first assembled by just using the peel-and-stick 3M material the door and all other windows are cut from. Never sure if I should also supplement this with additional dots of glue.
