Carolina Craftsman kit Rural Post Office.
Started by ACL1504, February 01, 2018, 05:53:41 PM
Very, very well done!  I likey the flakey.
sdrees
Quote from: ACL1504 on February 08, 2018, 03:16:54 PM
Quote from: sdrees on February 08, 2018, 12:06:44 PM
Hi Tom,
this is a different way to do the peeling paint.  I also like the second sample.  Very nice.
Steve,
Thank you. I wanted to try something different and this is certainly different. I won't do it again. It wasn't hard, just very time consuming.
But Tom, sometimes that extra effort sure pays off as it did in this case
Steve Drees
SP RR
Quote from: Donato on February 08, 2018, 10:19:37 PM
Tom, I know you know....
Donato,
I certainly appreciate the inference, but honestly I'm just one of the guys.
Thanks for following my friend.
Quote from: jerryrbeach on February 09, 2018, 09:20:50 AM
Definitely some of the most realistic aged and peeled paint I have seen.  Most I see is out of scale IMO.  Yours looks great!
Jerry,
Thank you, much appreciated. It took me a few days to come up with how to make it look like that. Time well spent some would say. Not sure I'll do it for all future pealing paint.
Again, thank you.
Quote from: Oldguy on February 09, 2018, 11:08:09 AM
Your kind and generous compliment is most appreciated. I likey the flakey as well. This time something worked.
Quote from: sdrees on February 09, 2018, 11:27:43 AM
Hi Tom,
Steve,
Steve,
Agreed. But not sure I'll do it for all pealed paint effects.
Prior to painting the walls, I wanted to distress the walls some.
I started with a side wall in case it didn't turn out or I ruined it.
For the bottom skirting I used a wire brush and a metal straight edge. I brushed along the edge of the ruler.
When finished, it did the same on the walls only I brushed vertically along the boards and batten.
No pictures as it doesn't show that well.
I was satisfied with the results so I did the other three walls.
I then applied a coat of Hunterline Light Gray to all four walls. I set them aside to dry.
When the A&I was dry, I applied the first coat of white paint to all walls.
I set them aside to dry prior to adding the second coat of paint.
While the walls were drying, I moved on to the screen doors. As I mentioned earlier in the thread these doors are fragile. Jeff did a great job in the designing them.
As you can see from the photo below, the screen door is smaller in width than the door. The plastic door has a frame around it.
Well, it's Diet Pepsi time, back in a few minutes while I grab a cold one.
Ok, that's better.
I used scale 2x2's and framed the screen door.
I added the 2x2's to the top and each side but NOT the bottom. Fast forward and finished.
The problem now is that the screen door sits to high/far from the wall and doesn't look natural or correct.
More on this later this afternoon.
Jeff includes with the screen doors a small three bar portion that I only assumed could replace the small horizontal bar in the middle of the door.
This next photo shows that I cut out the center of the door and installed one of these three bar portions.
I decided to try a little experimenting with the plastic door included in the kit.
I used a new #11 blade and cut the door from the frame. A couple of passes using moderate pressure and the door came out nice and clean.
I put the door in the door opening and set the screen door on top. I did not use the plastic door frame in this test.
As you can see in the photo above, the door alone is short so the frame is needed for it to look correct.
I put the door back in the frame and glued it in place.
I need to load and crop a new set of photos for this thread. I'll be back in about an hour or less.
I noticed when I had the door frame out of the wall door opening, the screen door fit flush against the wall.
This of course looked much better to me so I got to thinking. Yea, scary isn't it?
