Re-post of my Indiana Layout
Started by John B, July 12, 2014, 01:32:47 PM
martin.ojaste
What are you waiting for, go for it!
John B
#16
Once again, what you are about to see has been done...but as you will see, I have made a lot of mistakes, bad decisions, and after 10 years the current layout condition will  surprise you.
After considering everything that I wanted to do with the basement, my layout size shrank from the full basement to it's present size of 12 x 24 foot size. I've laid out my space, hung up furring strips and put drywall up for the backdrop
John B
Cannot figure out how to post a picture and have a description underneath it and then post another picture below that; so I will have to post individual pictures on at a time.
Joan's sewing room is on the other side of the layout room. I hung drywall on the back of her shelving for the backdrop
John B
I've painted the backdrop sky blue and am ready for the framework.[/size]
John B
Wrong! This is not the way to build a railroad. I needed solid walls for the train room. So I ripped everything out and put up 2x4s for the wall then insulated it to keep it toasty.
John B
The floor was cold so I put in some carpeting. I figured that if I built a layout, the ceiling would be hard to install; so I put in lighting and AC/Heating ducts into the room.
I put up furring strips and installed tempered hardboard this time instead of drywall for the backdrop. I lost a little layout space in the corners because I curved the hardboard instead of butting it up to the walls. I think it will look a lot better.
John B
I've painted the hardboard sky blue again and am back to where I was a few pictures back; but this time I started out on the right foot (I hope)
This process probably took 4 months. Remember, I work very slow.Next comes the trackplan. At this point I really don't have a plan yet; although I leaning towards one in particular
NOTE:  I put a plastic drop cloth over the new carpeting...at least I did one thing right
John B
We are now looking at December 2005. I am need of a good trackplan here and I needed a little step-by-step instruction to go along with it. I found the Kalmbach Book: the Pennsy Middle Division by Dave Frary published in 1996. It's a little hard to get now; but well worth it for beginners.
John B
With track plan in mind. The framework begins. Standard L girder construction. Using 1x2s, 2x2s, 1x3s and 1x4s
I put some plastic down first to keep the carpet clean. Note to self: Don't put plastic under legs next time. You can't get plastic out
John B
#24
This is my standard train building garb; sweatpants and a t-shirt.
John B
#25
Starting to build the framework for the mountain area.
John B
I added a little fiddle yard to the basic trackplan. I didn't particularly like the yard location in the original plan
John B
#27
I got some 2-inch foam for the layout support.
John B
I cut out a temporary section for a future access area.
John B
I transferred the cutout section onto the foam and placed it onto the framework to check the fit and looks.
