FOS Red Bird Taxi -2022 Build Challenge
Started by ACL1504, December 09, 2021, 05:25:12 PM
I painted the corrugated panels with the galvanized tin paint and let dry overnight. I then used a light rust, medium and dark rust washes on the roof. I'll weather if more after I get the office roof weathered.
I glued the wall section to the underside of the roof and let it dry. I used the main office to hold the roof in place at the correct angle while the glue dried.
Continued -
Now the roof and wall are one piece. I can add it to the office once the office roof is on and weathered.
I used scale rolled asphalt roofing material from Stoney Creek. The paper is thicker than regular roofing paper found in most kits and it feels like asphalt roofing.
It is listed a red but it appears more of a burnt orange color.
Back after getting a cold Diet Pepsi.
This next photo gives you a better look at the material. It has a texture to it and is very realistic.
I used a glue stick to hold the paper on the cardboard roof panels. The glue stick is an Elmer's Glue product from Staples. It is purple in color but dries clear.
I glued on both sides and let dry overnight. I used a new #11 blade to trim off the edges.
I added the roofing material to the two ends next. I let these dry overnight also.
The ends were trimmed to match the roof pitch. I next moved to making the ridge pieces.
Continued -
Don't worry if you don't perfectly cut off the sides. Mine looks pretty sloppy but the ridge cap paper will cover this.
I used a short metal ruler and guesstimated the width of the ridge. I used a #17 flat blade to bend the paper up at about 45 degrees.
Continued -
I then moved the ruler back equal distance from the center and used a #11 blade to cut the ridge.
Easy Peasy! Back in about 30 minutes or so.
I was able to cover all four hip ridges and the top ridge with two cut pieces. I laid each piece on a piece of cardboard, applied the glue and then pressed the ridge pieces in place on the roof. When dry, the excess was cut off.
For weathering, I chose to use loose pastel chalk. I dipped a pointed soft bristle brush into the chalk and "painted" it under each piece of roof paper as shown below.
Continued -
I then used a stiff brush and pulled down from the top.
Continued -
Everything looks outstanding Tom. How sturdy is the open air garage? I had something similar years ago and it was very fragile.
I like how you did the roof weathering, thanks for the tutorial...
craftsmankits
Looking great Tom.  Thanks for the tutorial.
Great job on the roof & weathering Tom..... 8)
