SS Ltd Drug Store Build
Started by GaryMc, December 11, 2021, 08:19:43 PM
GaryMc
Off until January and hoping to make some good progress on the Drug Store. Been working on interior details, walls and furniture and found my helper sleeping on the job. Not sure on what the kit manufacturer was thinking on the embossed brick sheets but the embossing stops short by about 1 1/2" of the end of the sheet. If they would of embossed the whole sheet there is enough material to be able to cover the wall assembly in one long continuous piece, instead you have to splice on a piece....oh well. Not real happy where the brick joins together but looks some better after I rolled the seam down.....glue was still wet.
Regards,
Gary
hey Gary:
You are progressing right along. Great work so far.
Those SS Ltd kits are a challenge but they do produce nice structures!  Keep with it, you're making good progress on what can be a tough build.
GaryMc
A few more pieces to the puzzle have been assembled for the first level walls and entrance for the apartments above. I replaced the brick embossing where I tried to tooth the brick together and moved the joint to the tower....much happier now. Graffen hope you don't mind if I go with a color scheme close to yours, the lighter colors show the details better in my opinion. The re-designed layout for some of the walls that have been changed from cardstock to bass wood.
Regards,
Gary
Graffen
Nice!
That building almost tells us the paint scheme itself!  8)
The light color scheme I used actually makes the details more obvious.
Hey Gary:
That coming along nicely. I'm following along.
Kaerl
GaryMc
Interior details for the second floor are now finished, completely scratch built and it's only 1 out of 3 to do....at least the pharmacy interior has cast detail parts.
Regards,
Gary
That is exceptionally nice detail work, Gary.  I'm enjoying watching your progress.
--Opa George
George Nagle
Harrisburg, PA
Hey Gary:
What can I say but beautifully done.
Excellent interior details Gary..... 8)
GaryMc
So much has happened in the last 3 years, the wife's COPD has gotten much worse and made the decision to retire from my job so I could be here to help her out more. My extra time is now spent on model railroading and getting caught up on things I let sit. I have made some good progress on this kit and have completed the interior details and have moved on to all the windows and trim pieces. Will post some more pictures of the progress once i can get them moved to my computer.
Regards,
Regards,
Gary
