FOS Gorman Sign Company build
Started by ReadingBob, April 27, 2024, 10:45:26 AM
Quote from: Jerry on May 10, 2024, 12:03:57 AMJust saw your new build here.  Retirement must agree with you because your already set up and moving right along.
Really like the coloring on this one.  And your usual neat and careful planning of things.
Nice tutorial as always.
Thanks Jerry!  Happy to have you following along.  I'm really pleased with how this one is working out.  It's a neat little kit with some wonderful details.
Quote from: oldiron on May 10, 2024, 08:13:00 AMA little late to the party but would painting the black inside with an oil base paint reduce the warping? Bob
That might help but most of the warping seems to occur when the Hunterline Weathering Mix is applied.  That's pretty thin and the wood just sucks it up.  Even when painted.  Some of the walls, in this kit, are more susceptible to warping because of all the openings they have due to other parts being cut in the non-viewable area.  Bracing solves most of the issues and the final construction takes care of the rest.
Thanks for following along!
Quote from: deemery on May 10, 2024, 08:49:59 AMClever idea for the adjustable lighting rack!
Thanks Dave!  I wish I would have thought of this a long time ago.  It saved me time and made the construction a lot easier.
Quote from: Jim Donovan on May 10, 2024, 09:01:07 AMI agree, neat idea! Great work and looking forward to more now that you have reached the seven days of Saturday stage of life.
Thanks Jim!  I'm enjoying the seven days of Saturday stage for sure.   ;)
Quote from: GPdemayo on May 10, 2024, 09:16:57 AMLooking good Bob..... 8)
Thanks Butty!  This is a fun one.  Hope to be able to bring it down to Tom's one of these days for show and tell.
Hello Bob, I can see that retirement agrees with you. You're doing your usual fine job with this build. Everything looks good and I have no idea how you can bend that small diameter tubing with the wires inside and not damage the wires.
Quote from: nycjeff on May 11, 2024, 07:00:45 PMHello Bob, I can see that retirement agrees with you. You're doing your usual fine job with this build. Everything looks good and I have no idea how you can bend that small diameter tubing with the wires inside and not damage the wires.
Hi Jeff.  Yeah, bending that tubing without pinching the wires is a real trick.  I can't tell you how many I've ruined that way.  It takes a lot of practice, patience and luck to get one that works and looks decent.  Thanks for following along!
 Happy Retirement !
Great way to kick it off. Neat structure by FOS. Not on the que shelf here but a neat kit to show off your modeling skills. Will pull up a chair...
 Tommy
Quote from: tom.boyd.125 on May 14, 2024, 08:46:22 PMBob,
 Happy Retirement !
 Tommy
Thanks for following along Tommy!  Yes, I liked this one from the moment I first saw it.
Bob, have you tried one of these Kadee coupler adjust tools to try bending the tubing?
Quote from: Zephyrus52246 on May 18, 2024, 05:32:40 PMBob, have you tried one of these Kadee coupler adjust tools to try bending the tubing?
Good thought and yes, I did.  It didn't work like I had hoped it would.  It still caused pinch points in the tubing.  I have a small needle nose type pliers where both sides are round (like the one side of the Kadee Coupler tool).  I've had some success using that and making a series or very small bends.  I just have to remember to be patient, go slow, and not make any of the bends too sharp.
Bob, I wonder if you can find a soft (copper) wire that you could feed into the tubing, and then try to bend with the tubing filled with that soft wire?
Vietnam Seabee
I wonder how this Fasttracks rail bender would work
https://handlaidtrack.com/product/tl-0004/
Kind of pricey tho 89.00
Terry
Quote from: deemery on May 19, 2024, 10:50:36 AMBob, I wonder if you can find a soft (copper) wire that you could feed into the tubing, and then try to bend with the tubing filled with that soft wire?
Good thought but it's tough enough to feed the two leads from the LED thru the tubing, prior to bending it.  I doubt I could anything else thru there.  This stuff is tiny.  :o
Quote from: Vietnam Seabee on May 19, 2024, 08:54:24 PMI wonder how this Fasttracks rail bender would work
Terry
That's a good thought Terry but it wouldn't make bends small enough for a gooseneck lamp in HO Scale.  It's just a bit too big.   ;)
