FOS Ideal Hosiery
Started by nycjeff, April 08, 2025, 07:21:02 PM
A few more pictures, before it goes on to the base.
The base for my street block of small businesses is some thin styrene with the building footprints taped off. The base pretty much fills the site on my layout. This way I can do much of the scenery work on the workbench and then just touch up the scenery around the edges of the base when it goes onto the layout.
I first sprayed the base with a rattle can flat grey primer. When dry I removed the tape. I then use some brown craft paint as a base then sprinkle on some sifted dirt from my yard. Next I dribble on some water and matte medium mix to set everything in p[lace. I then come back for the next layer of scenery- different types of ground foam and maybe some detail castings. In this picture I'm ready to place the structures on the base. I do the front scenery after the buildings are in place so that I can blend the scenery in a little better in areas that will face the aisle of my layout.
That's it for now, more later when I'll have some pictures of everything on the layout.
Great job and fast build. Well done.
That's one of Doug's better designs, I think.  The complex roofline works on this kit, although it does generally look a bit over-compressed.  At least there aren't any funky overhanging 2nd story pop-outs.   Jeff's construction and finishing is first-rate.
Wonderful job, Jeff!  That's a lot of eye candy in a small amount of space.  It's going to really pop on the layout. Two thumbs up on the job you did with this one!
Quote from: ACL1504 on April 14, 2025, 10:15:58 AMJeff,
Hello Tom, thanks for looking in and for the kind words. Truth be told, it wasn't that fast of a build. I didn't start posting until I was just about finished with the build.
Quote from: deemery on April 14, 2025, 10:22:44 AMThat's one of Doug's better designs, I think.  The complex roofline works on this kit, although it does generally look a bit over-compressed.  At least there aren't any funky overhanging 2nd story pop-outs.   Jeff's construction and finishing is first-rate.
Hello Dave, I agree with you, it is one of Doug's better designs and thank you for the nice comments.
Quote from: ReadingBob on April 14, 2025, 06:19:27 PMWonderful job, Jeff!  That's a lot of eye candy in a small amount of space.  It's going to really pop on the layout. Two thumbs up on the job you did with this one!
Hello Bob, thank you so much. I had a lot of fun with this build.
Here's a look at the last workbench photo. I finished the scenery in front of the buildings. Working this way, it's much easier to spin the whole scene around to get at all sides.
On the layout next to Pop's store
And with the luncheonette on the other side
And a look at all three together
A couple of drone shots and we caught the end of a passing freight train on the rear track.
The shelf here is only 18 inches deep. I like the way that the street block of businesses are in front of the moving trains in the rear. These three craftsman kits took the place of a Merchants Row styrene kit that I built early on in my layout history.
I had a lot of fun with all three of these builds and I am very pleased with how they look on the layout. Thanks again to all who took the time to look in and comment. Next, it's on to a re-build of a corner grain elevator scene. After all, as we all know, a layout is never done.
Beautiful scene! That roofer needs to kick it in high gear! He been working for a month! ;D
Nice job on the build, its fits the space like a glove.
Terrific scene, Jeff.
This build has come up very nicely.
Great build and terrific scene, well done Jeff..... 8)
Quote from: Philip on April 15, 2025, 10:45:58 AMBeautiful scene! That roofer needs to kick it in high gear! He been working for a month! ;D
Hello Philip, I think that's called job security and he's got more work waiting for him at Pop's store roof.
Quote from: PRR Modeler on April 21, 2025, 01:18:05 PMTerrific job Jeff.
Thank you Curt.
Quote from: ACL1504 on April 21, 2025, 05:40:30 PMJeff,
Hello Tom, thanks for looking in. I had fun with this one and it does fit right into that space.
Quote from: Mark Dalrymple on April 21, 2025, 05:53:03 PMTerrific scene, Jeff.
Hello Mark, thank you for the kind words.
Quote from: GPdemayo on April 22, 2025, 03:04:24 PMGreat build and terrific scene, well done Jeff..... 8)
Hello Greg, thank you so much. I'm very pleased with how my little row of businesses turned out. I was next going to re-build a grain elevator scene in a corner of my upper level, but I've had to shift gears since I now, thanks to Jim and Craig, have to make room for a large flour mill scene.
Howdy Jeff, great looking street you are developing, and the structures are fantastic.  Really nice work.  Have fun, mike
Hello Mike, thanks for looking in and taking the time to comment and I am having fun !
