3d killing me.
Started by KentuckySouthern, November 01, 2025, 09:23:44 AM
Rail and Tie
Something else to look at.  I found the memory sticks that came with the elegoo mar3 and 4 were flakey at best. When plugged into the machine, they would sometimes come up empty. When I put the stick into another of my elegoo machines, it worked. I also found that when I wiggled the drive in the slot it would also bring the files up sometimes. Other times just empty boxes like Karl mentioned.
My solution was to get new sticks and to bend the metal cover over the usb plug slightly so that it would be a tighter fit in the slot so that the pads were forced together better.
Darryl Jacobs
Inter-Action Hobbies
www.interactionhobbies.com
KentuckySouthern
Quote from: jbvb on November 02, 2025, 10:42:30 AMGiven lazy enough programmers, it could be that Karl's filename simply doesn't have the right extension: e.g., it wants ".ctb" but the file has no extension, or its extension is .CTB (upper case) etc.
That is quite possible.  I'll look into that when I get back at the conflict.
Thanks all adding info.
Howdy Karl,
IMHO, FAT32 is the best format for the thumb drive. It is what I use on the Elegoo Mars 3.  I save my files to several  thumb drives, all formatted to FAT32 with no problems.
Good luck and have fun,
KentuckySouthern
Shazam!
I've made great progress, thanks to all the positive suggestions here, I discovered that I do indeed need a Fat32 memory stick and a .CTB thpe file.  The Geek Squad helped me with formatting an older memory stick we have into the FAT32 property and I removed all the files I'd fubared up and did a fresh start and save in the .ctb format ChiTuBox that runs on my Mars 3 pro.
I have that file running on the machine now.
Thanks again for the help!
KentuckySouthern
Now, I "just" have to relearn how to draw.  Anyone using ChatGTP for drawing anything yet?
One of the auto companies just "killed off" 400 graphic artists... :o
KSinthe Ether
Congrats on burning through the IT problems, Karl!!
Great News!
I have the free version of chat and didn't really understand the procedure. They want me to go subscription to send a STl file. I think you still have to dump the stl into blender to clean it for printing. Model u has stl files for sale. Was thinking about purchasing the set with the figures moving burlap bags around.
Mill workers
Tinkercad has added a revolve and sketch tool. I'm crawling trying to figure it out.
Anyhow, good news Karl.
What are the rules for the ModelU files?  Could you print figures from those files for other people?
KentuckySouthern
Well, I did get a couple steps along the learning curve but have a way to go.
At the end of the day I definitely have learned that a Fat32 stick with a .ctb file works...
Now...learn to make a proper printable file
I got terrific supports..
had issues and laid down on the job
I need more work on my preparation work.
But, progress has been made!  ;D
Howdy Karl :-[ , congrats and persist!  ~mike
Dave, I think as long as you use them for personal use and not resell.
Looks like it needs more support Karl. I'll 2d the persist. congrats!
Having done my fair share of printing, I can say with certainty that it needs more supports.
KentuckySouthern
Agreed, Craig.  Trying to get a handle on slicer software now.  Chitubox 'free' or pay or Lychee, will be in my testing regimen as the seasons change. :o  :-\
KentuckySouthern
Quote from: KentuckySouthern on November 06, 2025, 08:51:01 AM
Quote from: friscomike on November 04, 2025, 01:57:31 PMHowdy Dave, congrats and persist!  ~mike
Karl? ;D
I'm not sure if Karl should be complimented or insulted by this typo!    :o
