Recipes for Alcohol weathering, better known as A & I
Started by ranny9, January 21, 2015, 06:56:33 AM
ranny9
No, not THAT kind of alcohol! I have one pint bottle of 99% alcohol with 2 teaspoons of Higgins waterproof black ink in it, and I have it labeled "Medium". Would you consider another bottle with 1 teaspoon ink to the alcohol as "Light" and another bottle with 3 teaspoons ink to the alcohol as "Dark"?  Or do you guys and gals go further apart or closer together, ratio wise, in your recipes of ink stains?
Randy,
I haven't tried the Higgins.  I use a cheap black ink I picked up at Staples that's used to refill ink pads.  I mixed up two teaspoon of that into a bottle of 90% alcohol and I consider that to be too dark to use as is.  I pour it into smaller jars I keep on my work bench and lighten it up by mixing it with some clear alcohol as I fill those jars.  No formula though, I just wing it.  I keep two bottles on my work bench.  One light and one dark.  I also keep a third bottle with clear alcohol in on the workbench as well.  If I feel that even the light mix is too dark (especially when I'm toning down whites, yellows, tans, etc.) I first dip my brush in the clear alcohol and then the light alcohol.  If I didn't realize it was too dark until after I started brushing it on something I brush the clear on while it's still wet to cut it.  Basically I just wing it.   :D
Randee,
Like Bob, I use to mix my own but over the past several years I've gotten lazy. Ok, very lazy in that I now use the Hunter Line Weathering Mix (A&I).
www.hunterline.com
I use the Creosote black(heavy)  and the Light Gray(light). If I want a medium I pour some of the Creosote Black into a spare bottle and add some rubbing alcohol to make it lighter.
Hunterline is usually at the EXPO's.
Often I'll start with the light and if I don't like the results I'll apply a second coat. Much easier to add the A&I vs. removing it once applied.
I just checked the Hunter Line schedule and they will be at this years EXPO.
Quote from: Randee on January 21, 2015, 06:56:33 AM
Randy
I have 4 different bottles of A&I labeled 2, 3, and 4 for the number of teaspoons of ink to the pint of alcohol.  The forth bottle is labeled trestle and is a mixture of 4 teaspoons of black and 2 teaspoons of brown Higgins Ink. For most weathering applications I use the 2. The trestle mixture was the result of some experimentation looking for the combination I liked the best.
NEMMRRC
Where did you find 99% alcohol?
I follow Sellios' recipe. I don't have an instruction abbet handy so I cannot quote it.
I only make one kind. If I want darker stain I just leave the wood in the A&I jar longer.
Jaime
Mike Engler
I get 99% from the pharmacist. They can order a big container for you (litre?) or give you a couple of pints if you bring some empty containers. You don't get much warping with it.
mike.engler59@gmail.com
NEMMRRC
Quote from: Mike Engler on January 21, 2015, 09:07:09 AM
Thanks.
I think I'll order the large container and transfer that to empty pint jars of the stuff you find on the shelf.
Jaime
99%?  Nice.  I'll have to check that out.  I use 91% which I get at the local CVS pharmacy.  I have 2 strengths of A&I:  1 or 2 tbs per pint (light or medium), but I also have a bunch of the Hunterline bottles in different colors/shades.  I swop back and forth depending on my mood.  Hunter line will be at Springfield this weekend, so I need to check my stock.
Randy...
Recall from previous conversations I use aniline dye.  These work very much like A&I so I can answer here.  I have used A&I in the past but the black is too stark for me.
Neither of these methods us a sealer like Minwax or other commercial stain sealer products.  Therefore you can put multiple applications to get what you want as far as darkness.  I don't soak strip wood for several reasons: no control over darkness and warping.
I use a wide brush that carries a lot of liquid.  I stain on a plastic baggie sheet that is later disposable and once I have rolled the pieces around I move them to another location on the plastic so as to not soak up stain on the bottom that I might not know about until later.
Repeated applications do not need to be done on completely dry wood so repeat applications can happen over a short period of time.  The alcohol goes off pretty fast so dry times are shorter than water or oil based stains.
I like quick...
see ya
ranny9
Quote from: ReadingBob on January 21, 2015, 07:33:26 AM
Randy,
The Higgins was something I picked up at the Pearl Art store down the street here in Alexandria, before they went out of business. A little ink goes a LONG way. I still have some Rapidograph around, from my college days when I was a draftsman in 1965...
ranny9
Quote from: ACL1504 on January 21, 2015, 08:05:55 AM
Randee,
www.hunterline.com
I have lots of the Hunterline stuff here.
ranny9
Quote from: S&S RR on January 21, 2015, 08:51:24 AM
Randy
I have 4 different bottles of A&I labeled 2, 3, and 4 for the number of table spoons of ink to the pint of alcohol.  The forth bottle is labeled trestle and is a mixture of 4 table spoons of black and 2 table spoons of brown Higgins Ink. For most weathering applications I use the 2. The trestle mixture was the result of some experimentation looking for the combination I liked the best.
TABLEspoons, or TEAspoons? Big difference...
ranny9
Quote from: NEMMRRC on January 21, 2015, 08:55:06 AM
Jaime
My local Safeway grocery store carries 71%, 91%, and 99%, in the pharmacy department. I think the only difference is the added inert ingredient of water.
ranny9
Quote from: MAP on January 21, 2015, 09:23:10 AM
Again, I'm curious...TABLEspoons, or TEAspoons?
