REA Freight House FOS Scale Models
Started by postalkarl, April 12, 2016, 06:26:36 PM
Hi Guys:
Took A photo with some FOS Scale flats behind the structure.
Hi Dave:
Thanks for the reply.  Much appreciated.
karl
Quote from: postalkarl on May 05, 2016, 10:42:44 PM
Hi Guys:
Karl,
Looks great as do the flats.
Hi Tom:
Thanks appreciate your compliment. Thanks.
Hi Guys:
I detailed the back platform. Here's a photo.
Hi Guys:
Working on the rear upper office addition to the station. Also painted up the part for the laser cut hand trucks. There are 4 in the kit but I damaged one of the frame shuffling parts around. Here's a photo of the part to the hand trucks.
Hi Guys:
I decided to deviate from the instruction a little bit here. Instead of waiting till the walls were assembled and the sub roof was on I decided to install my corbels while the wall were flt. Just seemed easier than assembling it and turning the building upside down to install the corbels.
Hi Guys:
I actually assembled 1 of the laser cut hand-trucks. Went way better than I thought it would. Just be very careful not to drop any of the parts as they are very small.
Hi:
Opps one handle is a little crooked but they are so small you can't see it on the model.
H:
3 hand trucks are assembled. 2 are on the model one on each platform. The 3rd will go on the other platform when it is built.
Hi Guys:
Here's 2 finished walls for the upper rear office.
trainguy2024
Very nice.  What type of paint did you use on this kit?
Hi Trainguy:
Thanks for the compliment. The following paints were used on this kit:
1) Floquil Depot Olive, Zinc Chromate primer And Earth.
2) Krylon Spray Red Oxide primer. Almost an Exact match for Floquil Zinc Chromate primer. Roof and windows and doors are sprayed with it.
3) Apple Barrel #20526 Country Gray for dry-brushing.
That's about it except for A&I washes.
donatode
Still looking good .... and I'm still tagging along.
