SierraWest O'Neills Fabrication
Started by SteveCuster, June 28, 2016, 11:33:47 PM
Hi Steve:
The roof looks wonderful. WOW!!! you even made cap shingles. You don't see that very much. Can't to see it on the building.
SteveCuster
Thanks Karl!
The cap was the most tedious part, it took a good amount of patience to get everything lined up correctly. Should be adding some color and the finial tonight.
-Steve
Steve Custer
SteveCuster
Good morning everyone, I finally got to apply some color to these shingles.
I finished all the hip shingles, I let them dry for 24 hours before I did anything to them for fear of disturbing them. All the shingles were glued on with Franklins Titebond II.
I wanted to avoid coloring the roof with any washes if I could help it. I believe the Titebond II glue could hold up to the solvent or alcohol but I was concerned about the roof card warping. I started with 408.5 Raw Umber as the base roof color.
I applied Rembrandt 408.5 to the entire roof with a little 408.7.
I drybrushed some Apple Barrel Granite Gray on the shingles.
I liked the color of the shingles until I placed the colored roof on the structure. I didn't like the roof against the color of the wall, I thought the roof was too light to me and it looked wrong.
I went over the roof with 409.3 this time, a darker brown color. You can see the color shade difference in this picture.
This color looked much better to me. I think it gives a more subtle transition between the 2 colors.
I wanted to add a copper roof peak cap before I added the finial to the roof. I see this detail a lot on some of the older buildings around my town. I used the copy I made earlier of the roof card, I cut out the peak and folded it together.
For the copper color I painted the paper with Rust-Oleum dark gray automotive primer, followed by these 2 colors combined to make a lighter whitish green. The paint was applied with a stiff brush dabbed on, I wanted a consistent paint color.
I painted the finial the same as the paper. I didn't blacked it because I wanted the base colors to match. I brushed it with some random brown chalks to tone it down. I need to touch up the glue joint between the paper and the casting, the epoxy is still drying in this shot.
Thanks for checking in,
-Steve
Steve Custer
Nice weathered copper look on the finial and the cap.  I wouldn't have thought of "painting" the shingles with pastels.  Looks great.
ger deguelle
martin.ojaste
Steve, no complaints here, well done.
Rail and Tie
Absolutely perfect!
Darryl Jacobs
Inter-Action Hobbies
www.interactionhobbies.com
SteveCuster
Thanks Jeff, Der, Marty and Darryl.
Steve Custer
ak-milw
Steve
It just keeps getting better and better.....beautiful work!
Wow - that's some very fine modeling!
SteveCuster
Steve Custer
Hi Steve:
Beautiful job on the roof. I just love what you did with the finial. Just perfect.
SteveCuster
Steve Custer
Hi Steve:
You are quite welcome.
