Scratch-building Cartwright's Machine Shop
Started by rpdylan, July 31, 2016, 07:00:08 PM
Your scratch build really turned out great. Very well done.
rpdylan
Thanks Tom and John! I really appreciate the kind words!
Bob C.
rpdylan
For the water pour I thought I would try this new product from Woodland Scenics- "Deep Pour".  After looking at the water around old mills, I am going to use the "Murky" color. The instructions want me to first place the bottles in warm tap water for 5 minutes- then its a 2:1 mix of base to agitator, stir for 5 minutes, let sit for 5 minutes, then stir again for another 5 minutes. The rest period is supposed to cut down on the "filming" of the surface. You can pour up to 1/2 inch with this stuff.... I plan on doing 2 pours to get the depth that I want. The mix is fairly thin and pours easily....
Bob C.
rpdylan
After the pour, this is what it looks like.  24 hours for cure time before I can do the second pour....
Bob C.
Bobby
Bobby - THE Goat!
The water looks great. Is the murky color part of the mix or is it an additive color to the entire mix? I doesn't appear to be leaching up the walls or trestle bent either.
Okay, I see the mix is murky out of the box. Missed the first photo.
rpdylan
Its been about 20 hours, the resin is dry. There is some creep up the walls and trestles but to be honest, its not too bad. I think that if I darken the stonework close to the water line before the next pour it will hide the creeping of the resin even more. All in all a pretty easy product to use, I really like the way the murky color looks, and it was nice to not have to try and tint the water myself. Its a great color for ponds or canals. I plan on adding a bit of wave effects to simulate a current/flow to the water.
Bob C.
richbeau
The look of the water is impressive. Nice work
--Rich
rpdylan
Thanks Rich. To be honest, I didn't do much. Put some dirt down and painted some dark splotches here and there, then did the pour. I really like the product, the pre tinted coloring makes things much easier. The stuff is thin and mixes/ pours easily.
Bob C.
ak-milw
Bob, if you paint on a little green paint at the water line it will look like natural alge and cover the creep.
rpdylan
Yeah, thats what I need to do,,,,that "slimy" dark green on the stones is what I need. I plan on doing some before the next pour so the dark color will be seen below the waterline also......
Thanks to everyone for your input!
Bob C.
HI Bob:
the water looks really great. I may have to get some of this stuff.
