Hi Jeff:
Love the way its coming out. Especially your roof. It looks really great. Also like the weathering on the walls.
Ditto to the other comments. Very well done and looking like an old structure.
Thanks, John.  Maybe Bob will send me a commission.   ;D
Thanks, Karl.  I've got a few shiny spots still.  Any handling of the roof and they can appear.  Funny thing, I was reading and old RMC and there was a prize winning mill in it and looking closely, I could see some shiny spots on the roof of that build as well.   :)  Once it's "planted" I'll use a fine brush and rust colored paint to try to cover them.
Thanks Tom, glad to see you following the build.
i finished the tar paper roof last week, and just finished up the rafters and trim under the entrance roof.  I'll weather the roof a bit more when I have it on a diorama base.  The next step is signs for the outside.  I usually put these on when the walls are flat, but the signs went missing for awhile.  I have since found them, but will hold off for now.  The doors go on after it's on a diorama base, so they won't be knocked off, so this one is done for now.  I'm going to start on the other structure in the kit next.
Powersteamguy1790
That build looks fantastic Jeff. :) 8)
madharry
A very impressive build Jeff. Thanks for sharing.
Mike :D
Formidable Jeff , the weathering and roofs are super.
barrymk
Thanks, gentlemen, the encouragement is appreciated!  I've started the small store.  First pic shows bracing.  I like the template card so I hopefully don't put  a brace where it doesn't belong.  The little piece with the window opening next to the triangular piece is a mystery.  I don't think it goes to the kit.  Probably belongs to something else and I got it mixed up into this box.  Anyway after bracing, I spray painted the back of the walls to help prevent warping.  I usually use black primer, but I don't have any, so some Rustoleum Flat Brown Camouflage paint substituted.  I then used Hunterline Light Grey Weathering mix for a base on the walls.
This structure is in much better repair than the auto repair one.  I used three thin coats of Apple Barrel Lemon Chiffon on the walls.  Vallejo Calvary Brown was airbrushed on the windows and will be used on the wood trim.  I didn't lift many of the boards.  For the 'nail holes' I used a tool made by R-B productions called the Rivet R that was suggested in the instructions.  It's like a pounce wheel, but it leaves very small round holes.  The wheels come in several "sizes", I used the 1 mm spacing (the instructions used 0.65mm), but I like how it turned out.  Saved a LOT of time vs "the Nailer".  A wash of black acrylic and it's time to put the walls together.  I tried out the "Diamond Glaze" on the windows, wondering how it would work on larger expanses of "glass" and it worked well, again saving me a great deal of time from cutting acrylic sheet.
Erieman
Dr. Jeff,
Somehow I missed this thread. You are doing a marvelous job on the build. I especially like the weathering of the structure. I have this kit in my "to build " area.I always enjoy the SRMW structures and look forward to your thread progress. Keep up the great work. This is an awesome build.
Frank / Erieman
