The Pub Crawl Build
Started by Zephyrus52246, October 24, 2017, 12:00:03 PM
I've been working on this one for about a month on and off.  Some days I'm gung ho and others, meh.  Kinda like I've felt since I started working again in June.  Hopefully the EXPO will provide a spark.  The Pub Crawl by Foscale will be a perfect addition to E. Dubuque on my RR.  Typical stuff in the box.  Minimalist instructions.
I square the edges of the walls on the Tru Sander to eliminate the "burn angle".   Then bracing.  Then into the paint booth for a coat of black on the backs of the walls.  Helps prevent warping, and nothing shows thru the windows this way (though I usually add view blocks later).
A coat of A&I on the stripwood and walls.  I added a second coat after it dried.  Spray painted the windows/doors a light grey.  The paint scheme Doug used is basically a monotone of Pollyscale Concrete.  I think it looks OK, and I wouldn't have to figure out what trim needed to be painted a different color.   :D
I built the roof billboard next as I wanted to leave it a natural aged wood color, and at the end of a build, I sometimes can let these sit for days, I was more ambitious early on this one.
Painted the walls and there was a bit of warping at the peaks where there was no bracing, so some was added (and later painted black).
I had started building a couple of freight cars before/during the build, so by this time the work area was a disaster.  I finished the rolling stock to clear that stuff out of the way.
Added the nail holes, and cut and lifted some boards.  I do the nail holes every 3 feet usually, not prototypical, and I don't press very hard, I like them subtle.  I use a Rivet R tool, it makes a small hole, not a line like some of the tools do.
There's one big "painted on" wall sign. I drybrushed this, glued it on with full strength glue, ran my nail over the clapboards (cover your finger with a plastic bag so you don't rip the sign).  Added the nail holes and some vertical cuts in the boards, raised a few boards, a coat of A&I and I think it looks OK.
There are a couple of windows which project out from the front to add interest.  This is where my troubles began.  The bay is a couple of laser cut pieces, went together OK and fit in the building OK.
The other window is lasered out in a flat piece of plywood, you bend the sides and fit some pieces in to "square it".  The pieces were a bit short, so I had to fit a piece of stripwood in the sides. You can see the gap on the bottom right.
The rectangular pieces are sized so it would drop right into the hole, it's close, but since I added the stripwood, it didn't quite fit.  Some trimming did the trick, and the bottom piece is not quite the same size.  I fitted a piece of stripwood into the hole to use as a backing to glue the lower piece on.  It doesn't line up perfectly with the window. But I think the structure will be angled or at the back of the scene, so no one will notice.
I used "Diamond Glaze" for windows except for the projecting windows, they are too big for this kind of stuff.  They had acetate which I cut to fit.  Of course by this time, I couldn't find the acetate supplied (after spending 20 minutes looking for it), but I have a large sheet of this for just such an emergency.  I used some small magnets as a weight to hold the window in place.
After cutting the signs out, I use some water color pencils on the edges to hide them, usually with a darker color if I can't find an exact match.
Some of the signs are just glued on, others have 2x4 edges to frame them.  Of course I painted what I thought was enough black for this sign, only a couple of millimeters short.   :o  So I had to stain, paint, restain another piece of wood.  I wonder why it takes me so long to build these things?  ::)
So the signs and doors/windows were added.  This led to the second problem, the top supplied for the bay window is too small.
