Pile Driver FSM #105
Started by postalkarl, March 05, 2018, 11:41:35 AM
Lynnb
Yep you nailed it. For the cable I think I would rather have to color something for cable rather than for rope, I think I used a grimy black for mine.
Ontario, Canada
The Great White North
Hey Lynn:
thanks for the compliment. What are you doing next?
Lynnb
Karl I'm leaning toward FSM Bailey's Produce. I'm a bit intimidated by it but I'm sure some of you gents have been through it and will help me out ;D
When I built the Bar Mills Hunch Landing I wasn't too keen on the wall shingling and now realize Bailey's also has them as well as stucco, errrrr.
Ontario, Canada
Hey Lynn:
I have that kit to build also. You'll get through it just fine I use Liqutex Stucco for my stucco. Am working on the A frame for the pile drive. After it is built and installed I'm finished with this kit.
Looking good Karl.  Another fine build. Your getting close.
Hi John:
Thanks appreciate it. Got one side of the A frame finished. On to side 2.
Lynnb
Aframe looks good, did you notice the difference in height between the two drawings ( left and right ) ?
Ontario, Canada
Lynnb
Quote from: postalkarl on April 03, 2018, 01:38:42 PM
Hey Lynn:
Karl I would imagine you have used the stucco that comes with the FSM kits in the past, did you not care for it? I'd like to try to stick to the components of the kit including the shingles, although when I did the Bar Mills Hunch Landing I liked the Bar Mills shingles for the walls ,some how I can't imagine using Campbell shingles that come in the kit although obviously they must do well seeing as the other types I would imagine were not available at the time. Thoughts?
Ontario, Canada
Hi Lynn:
I have never used the stucco in the FSM kits. It has no texture. I like the Liquitex much better. Thanks for the compliment on the A Frame. Yes I noticed the difference of left & right measurement. I'd say about 1/32nd of an inch by my measurement. I sanded the tops to match.
sdrees
Hi Karl
Your Pile Driver project is looking very nice.
Steve Drees
SP RR
Lynnb
Thanks Karl, I guess I over reacted with the different heights of the A frame sides , you're so smart ;D
Is this the stuff for liquitex stucco ? I want to get this right.
Ontario, Canada
Karl coming along nicely.  Nice neat job on the A-frame.
Hi Lynn:
Yeah that's the stuff.
Hi Jerry:
Lynnb
Quote from: Lynnb on April 04, 2018, 01:27:08 PM
Thanks Karl
Ontario, Canada
