FSM Bailey's Produce Co.
Started by Lynnb, April 08, 2018, 10:25:51 PM
Lynnb
So far its moving along pretty good, originally I thought I misplaced the weatherhead and after rereading realized I had to make it out of wood , i made it from styrene. I now have to take a couple steps back and do the rafter cross boards and signage.
Ontario, Canada
The Great White North
Lynnb
Thank Curt and Karl, it has been a learning experience. Work keeps slowing me down.
Ontario, Canada
NEMMRRC
Quote from: Lynnb on November 08, 2018, 03:25:55 PM
Thanks Jamie, drilling from the bottom at the time seemed to be the only other option, drilling from the top wasn;t going so well for that size of wire. Would be handy when wiring in real model  lites.
If I recall there are two sizes of wire in this kit. When I built mine I had to get both wires and put them side by side to make sure I was using the right one.
Jaime
Looks great so far!  I really like the colors and the weathering.
Spoiler alert - I got around this point in the build and found myself thinking "Wow, I'm almost done the main building."  Wrong.   ::)  There's still a lot of interesting "stuff" to add to it.   ;)
Lynnb
Quote from: NEMMRRC on November 08, 2018, 06:47:48 PM
Jaime
Yes the two wires are a definate size difference but pretty obvious in size, the bigger wire for the lamps look like they may even big enough for a tortoise switch machine throw wire upgrade.
Ontario, Canada
Lynnb
Yes Bob still some interesting stuff to add , signs , roof rafter support boards, roofs , canopy's  , can't think of much else though. I won't be attaching the building to the base rightaway so will have to skip the power wires. Looking forward to your update Bob.
Ontario, Canada
NEMMRRC
Don't forget the rafter tails !
Jaime
Lynnb
Jamie I think i did get all the rafter tails, didn't I?
Ontario, Canada
NEMMRRC
Quote from: Lynnb on November 09, 2018, 06:53:19 PM
The only way I was able to keep track of all that was if I little sticks of wood were still  left in the kit's box  ::)
Jaime
Lynnb
I think the main building is going pretty good , I took some time to put the brushes in my MEK jar, cleans them rght up. I'm also trying a new to me technique  using a mix of water, white glue and a drop of dish soap and the rembrandt chalks. Last up is time for a base.
Ontario, Canada
Lynn,
I find coloring shingles realistically is one of my personal challenges.  I am impressed by the fact you did the roof and wall shingles in two slightly different colors and both look equally realistic.
Really nice job with the build and coloring Lynn.
Lynnb
Thanks Jerry and Curt, Jerry I have many challenges in this structure building. :D
Ontario, Canada
