Lunde Studios The Bon Ton
Started by madharry, May 17, 2018, 10:34:04 AM
madharry
I decided to build this department store. The usual difficult process of trying to glue the walls together without getting glue everywhere.
The clamps came in useful and I used wires threaded throgh the windows to hold the main wall together while the glue takes.
The idea is to make the most of the four/five floors which are highly visible through the front windows of the department store as scene stealer..........
A bit of history for Magnuson were sold to Walthers, DPM were sold to Woodland Scenics and they were all started by Don Lunde; who has now a new company Lunde Studios. A great bit of re-cycling...............
Here's a trick to consider for that kind of difficult assembly:  Use something like Walthers Goo or a similar tacky glue to hold the walls in place, then lock them down with thin CA.  I've used this on resin car kits and it works well.
I'm glad to see someone doing a Lunde kit, I have a couple of them that I haven't started.
madharry
Thanks Dave, that is my method at the moment and it seems to work. Now where is the acetone to clean my hands from CA?
gleiphart
Wow. I was born and raised in York, PA and it is the home of The Bon Ton Department store. They just filed for bankruptcy and will be a bit of nostalgic history before too long. As I was growing up it was the home to the real Santa Claus. I have a photo of Santa arriving at the Bon Ton from the late 1950's. I also have a Jordan hook and ladder that I hope to recreate Santa's arrival from that photo. In the 50's and 60's they would animate the store windows and it was a big draw to the downtown shoppers. I will try to post a photo. May I suggest a Google of "the bon ton York PA" for some archival resources.
You bet that I'll be following this build.
Quote from: madharry on May 17, 2018, 01:48:41 PM
Nail Polish Remover is diluted acetone with some extra additives to make it easier on your skin.
Mike,
I'm following along also. Though I don't have any Lunde kits, I've always liked what they offered. Great start.
Following along , I have 2 Lunde N-scale kits.
madharry
Quote from: gleiphart on May 17, 2018, 03:07:47 PM
Thanks very much I will look into this..................
Mike :)
madharry
Thanks Tom I hope you are back to speed and also Jan...............are our countries contesting junior soccer? ......................
It is crazy here with Meghan and Harry fever..................
Quote from: madharry on May 17, 2018, 05:30:07 PM
Not anymore , we won  ;)
madharry
Quote from: Janbouli on May 17, 2018, 06:52:17 PM
Yes on penalities............hmmm
madharry
Continuing............
The two picture walls on the Bon Ton had a small gap which I filled with putty.
madharry
The method of successfully glueing the walls together is as suggested by Dave. Use a tacky glue first and then follow up with CA.  The model kit shown is another Lunde kit I'm working on.................
madharry
One of the doors on the kit was warped and as Tom suggested the best way to handle this is use hot water. I used an empty metal pie dish and added boiling water and hey presto the part straightens itself.......
madharry
Continuing...............
I never throw anything away according to my wife. These canopies came courtesy of Bar Mills Sweaty Betty's kit . However they were too small for the main display windows. So I just enlarged them 40% or so on my photocopier.
The roof is fairly simple. It just needs painting and the air conditioning units and chimney added..........
