Arch Bridge Construction
Started by sdrees, August 09, 2018, 11:48:09 AM
sdrees
Hi Terry,
I appreciate it that you are going to follow along.  Hope it works out OK.
Steve Drees
SP RR
Steve.....
That Unimat is the first of the later model.  You have me by about a year.
Regarding belts...........Don't pay anyone anything for them..........
Go to a good hardware supply or automotive supply and get neoprene O rings.   I think the larger one is a 3 1/2" by 1/8" and the smaller one is a 2 1/2" by 1/8".
They don't need the twist band that they originally came with nor do they need some trick this or that.
This is the 1960's........... things just weren't that complicated then ! ! ! !
Regarding learning stuff on it...........  Just get out there and start turning stuff.
It can be used as the following: common lathe, drill press, verticle mill, horizontal mill, a dremel with a cut off wheel can be set up as a horizontal post shaper......... and a bunch more.
Hopes this helps
see ya
Great project and great old tools - it doesn't get any better than this.
Steve,
Just getting caught up on the thread. WOW, fantastic project - love it and the step by step process.
All thumbs up!
sdrees
Steve Drees
SP RR
sdrees
Appreciate the comments John, Thanks!!!!
Steve Drees
SP RR
Hey Steve:
You are off to a good start. Looks great so far.
This is going to be an incredible looking bridge.
sdrees
Here is the latest progress on the bridge.  I am in the process of fitting the diagonal bracing to the bridge.
Steve Drees
SP RR
Following along with interest; I have a steel deck truss to build at some point.
vinceg
Fantastic piece of engineering, Steve. Wonder if Central Valley wants to license your design to make a new kit offering....
Vince
Steve,
Very impressive progress on an ambitious project. I'm late to tag along, but glad I did. Your method of attaching the bents to the jig is genius.
sdrees
Attached are progress photo's on the arch bridge.  I now have to fabricate and install gusset plates where the members come together.
Steve Drees
SP RR
sdrees
Hi George,
Thanks for stopping by.  I can't take all the credit for the jig.  But I modified a jib found in a Model Railroader bridge construction manual.
Steve Drees
SP RR
