FSM Barnstead Lumber Build
Started by rpdylan, October 21, 2019, 02:10:04 PM
PainTrain
I'm really liking the derelict building you posted earlier.
rpdylan
thank you to everyone that is following along!  I decided to tackle the chain link fence,,,, the steel rods provided are pretty hard, used my heavy duty dykes to cut the pieces.  I am not that good of a solderer so I used JB Weld (quick setting) at the joints.  the stuff needs to fully cure (6 hours). my plan is to file the joints to clean them up then I will attach the fencing material.  I will see if the JB Weld has worked.....
Bob C.
Hey Bob:
good idea I can't solder either.
rpdylan
well,
    The JB Weld was a failure,,,, the stuff just didn't stick to the steel rod and it all came apart.... so, I guess I'm going to have to solder the joints.  more to follow .....
Bob C.
I've never used JB Weld but soldering isn't that hard. The wire included in many kits will work fine but I prefer to use the same size in brass. Brass is much easier to solder than the steel wire. Once you try it I think you'll be hooked on soldering.
rpdylan
so I soldered the joints, using liquid flux and very little solder.  my first time doing this type of work and I will have to try the brass rod in the future to compare the ease of soldering the material. attaching the fabric with ACC glue is a bit trying.... here is a section sprayed with gray primer.
Bob C.
rpdylan
the warehouse is not glued down yet, but this is where it goes.... I had to get it in place to determine where the track lay and for the "concrete" bases of the chain link fencing.....
Bob C.
sdrees
Steve Drees
SP RR
Wow, yes, very nice, Bob.  It looks great in position.  Also good work on the chain-link fence. I haven't tried that type of fine soldering yet but yours turned out just fine.
--George
Hey Bob C:
Beautiful job on the fence. Also the building & lumber shed are just beautiful.
rpdylan
thanks guys!
    This kit is deceiving in the amount of work involved! lots of bang for your buck with this one! I've been nibbling away at castings painting and getting the fencing complete....
Bob C.
rpdylan
little by little more details are added to the side "junk"yard...
    The prototype has a solid chain link fence to the left of the front door, in between the warehouse and the cutting shed. I thought that I would like to have a yard entrance here, so my plan is to add a sliding chain link gate here....
Bob C.
