FSM Kit #295 Fox Run Milling Build by ReadingBob
Started by ReadingBob, June 01, 2014, 12:07:11 PM
Great work Bob.....I'll try to get by your place to check it out before you take it to Expo.  8)
ollevon
That looks awesome Bob,  can't wait to see it at the Expo.
  Sam
Perfecto and all that---- and more. Well done.
Slim Jerkins
Nice work Bob
I finally got a chance to catch up here. I like your lighting contraption. You might like making those even more after you try copper tape. Saves on messing with short lengths of wires.
If you want to warm up that one gooseneck that's a bit blue hit the LED with a little dot of the clear yellow paint from Tamiya.
Those three LEDs working off of a nine volt and a current limiter must be pretty dim unless you've got a really strong battery. With three white LEDs in series and a nine volt battery you can get away without using a current limiter. However, if you decided to run the model off of a 12 volt or higher power supply you'll risk burning out the weakest of those three LEDs
What? you didn't want to make another gooseneck light? I just got done making about fifty of them to take up to Springfield.  :P I've really developed a love/hate relationship with those buggers.
Congrats again on a totally awesome job.  :)
-slim
Quote from: nextceo on January 20, 2015, 08:19:27 AM
   Looks awesome! What did you do for the rooms inside the buildings? I like the inside of the room of the small building.
Alan
Thanks Alan,
To be honest I didn't do too much for the rooms inside the building.  I did add a figure (as suggested in the instruction) into the scale house room in the front of the small building.  That room turned out to be the biggest headache I had when I added the lights.  My original plan was to make the roof of that building removable but the smoke stack on the rear wall has guy wires attached to it that attach to the roof so I had to scratch that idea.  I had drilled a hole the interior wall just big enough to push a 3mm LED into.  I had cut an opening in the base so I could get to the interior of all the buildings.  Well, getting that LED into that hole after the fact was quite a challenge.   ::)  Eventually I got it in though.
If you look real close at the lower window in the stairway on the main building you can  see a little blue painters tape and a red wire.   :-[  It's an open window so I'll probably get daring and try to poke a small paint brush with some black paint on it to paint the tape and wire.  I could pull the contraption out and paint it but it was a tight fit and I'd rather not go risk doing that.   :P
Quote from: GPdemayo on January 20, 2015, 09:00:22 AM
Thanks Greg.  Yep, either swing on by or we need to have a SBG meet before the EXPO so I can show it the rest of the crew.
Quote from: ollevon on January 20, 2015, 09:47:00 AM
  Sam
Thanks Sam!  Much appreciated.  I'm looking forward to meeting all of the forum regulars that are attending the EXPO.  Should be fun!
Quote from: ACL1504 on January 20, 2015, 09:53:01 AM
Thanks Tom!  Much appreciated.  I'll bring it down one of these days when the Judge is around to show it off.   :D
First rate craftsman work as usual, Bob.  Can't wait to see it at the Expo.
Quote from: Slim Jerkins on January 20, 2015, 10:26:28 AM
Nice work Bob
-slim
Thanks Slim!   8)  I do need to pick up some of that copper tape one of these days.  I did hit those goosenecks with the clear yellow from Tamiya.  Maybe I need to hit it again.   :D
For the pictures I was powering this with the power pack from my Digitrax Zephyr.  The 3 LED's and 1 Current Limiter won't light with just a 9 volt battery.  I need to find a "no longer needed" power supply from something discarded and convert it to something I can use at the workbench for testing this stuff.  I have tons of old wall warts in a box somewhere.  I just need to find one that outputs at least 12 volts.  I typically use a 3 to 1 or a 2 to 1 ratio of LED's to Current Limiters so 12 volts is all I really need.
I'm running low on LED's and stuff.  I hope you'll be hawking your wares at the EXPO.   ;D
Quote from: Zephyrus52246 on January 20, 2015, 11:20:28 AM
Thanks Dr. Jeff!  Much appreciated!  I'm looking forward to seeing you and all of the other forum regulars at the EXPO.
coors2u
Bob, you have done a fantastic job on this build. I have really enjoyed following along as you went. Top notch work.
Dustin
Quote from: ReadingBob on January 20, 2015, 11:11:36 AM
Sounds like a plan Bob.....I'm looking forward to seeing it.  ;D
What Jeff said.  See you at the EXPO.
clevermod01
Thom at Clever models llc
