So long 99 cent Walmart gray primer
Started by NEMMRRC, January 01, 2021, 05:16:41 PM
NEMMRRC
Today I used up the very last drop of my Walmart 99 cent gray primer spray cans. I have not seen it stocked at Walmart for almost 4 years now. This primer went on smooth, sprayed on thin so it did not obscure details, dried super flat and made a great use for other paints.
I will miss you Walmart gray spray primer for 99 cents....
Jaime
Let me know what you think. For me, it did everything the same as the Walmart spray :)
rslaserkits
Quote from: Rusty Robot on January 01, 2021, 05:51:06 PM
Whilst it's not 99 cents, this will fill that hole in your heart almost exactly:
https://smile.amazon.com/gp/product/B002BWORZO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Yep but their nozzles  rot and clog up easy. End up trashing mostly fill cans because of it.
rich
vinceg
Quote from: rslaserkits on January 02, 2021, 01:23:20 PM
rich
Yeah, I'll second that. I would say it is probably more often than not that I have a can of Rustoleum paint that either sputters or runs out of pressure before I run out of paint. And, I try to clear out the nozzle after each use.
It does take me several months to go thru a can. Perhaps that is part of the equation. Maybe using it all at once would get better results. 'Course, I don't need it all at once....
Vince
NEMMRRC
It's become a religious ritual for me to turn the can upside down and spray two or three squirts after each time I use any spray paint can. I have had good luck with that practice for keeping the nozzles clear. However, I will make a note of this. Also, I clean up the nozzles from used cans and keep the extra nozzles just in case.
Jaime
