India Ink
Started by Dennis Bourey, February 25, 2021, 09:00:16 AM
Dennis Bourey
Hi Guy's, I found 2 bottles of Higgins india black ink in my stash. I made up a 16 oz of 91 % Alcohol and it looks like crap. I dumped in a bowl to use and everything is on the bottom separated. Is there a shelf life for this stuff? 20 years plus was in a train tote. I was wondering what stuff you great molder's use and your mixture for 16oz bottles or I can get 32oz if I can find them that size? Thanks Dennis
Dennis Bourey
dpbourey@comcast.net
Lake's Region RR
(Happy Modeling)
I use Dr Ph Martin's.
I know Higgins is good, but the one I bought once refused to mix at all with the alcohol. What ever ink I bought must've been the wrong kind.
For mixing, George's standard recipe of 2 tablespoons per pint of alcohol, seems about right. That said, I always test as I mix. It's easier to add more than take it out!
Dennis Bourey
Thank's Craig, I have a Dr Martin's I just bought but it is Sepia and it mixed well. I forgot to ask is it waterproof or non waterproof? Dennis
Dennis Bourey
Lake's Region RR
(Happy Modeling)
India ink is just a suspension in water, so no matter how old, if the suspension is still ok, it should mix easily with alcohol--maybe with some extra vigorous shaking.  Having said that, I have also had "blobs" from old india ink.  I discovered it was because the ink was so old that some of it had actually dried out in the bottle when I added it to the alcohol.  So the blobs were dried bits, not bad ink.
--Opa George
Dennis Bourey
Thank you Craig and George. I shook it for minutes when I made it and when I set the jar down I put it in a bowl or use brush it just alcohol on top and you can see the pigments on the bottom.Dennis
Dennis Bourey
Lake's Region RR
(Happy Modeling)
Jim Donovan
Dennis you are not alone, I have had the same thing happen and the ink was only a year old. Now I test and then test again before applying.
Jim D
Holland & Odessa Railroad
Dennis Bourey
Thank you Jim. I will get a jar of india ink tomorrow while out shopping...Dennis
Dennis Bourey
Lake's Region RR
(Happy Modeling)
BandOGuy
Dennis,
Thanks for taking time to post what's been on my To-Do list forever.
May list is not really long, and a lot of it is model railroad related. If you're near Philly, you're more than welcome to stop by and work on more of the list.
SteveCuster
I use Higgins brand Non-Waterproof. It comes in the square jar instead of the round one. I think the non waterproof mixes better but I have had good results with both.
Steve Custer
Dennis Bourey
Thank you BandO. Steve Thank you, Steve that's the same one's I have but I just bought the Sepia recently and it worked. My other 2 higgins are black ink bottle won't work and it's probably that there 20 years old lol. Dennis
Dennis Bourey
Lake's Region RR
(Happy Modeling)
Hey Dennis:
That's what I use and it works fine. Don't know about A shelf life.
Dennis Bourey
Hi Karl, You say you use Higgins? Thanks Dennis
Dennis Bourey
Lake's Region RR
(Happy Modeling)
Just looked for my bottle of ink.  It's dried out as well.  Higgins non waterproof.  My A&I bottle date is over 5 years old, I suspect this ink bottle is closer to 10.
Dennis Bourey
Thank you Jeff...Dennis
Dennis Bourey
Lake's Region RR
(Happy Modeling)
