Thursday - August 5, 2021
Started by ReadingBob, August 05, 2021, 07:09:08 AM
Morning all,
Still sending good thoughts for a speedy recovery your way Raymo!   ;)
Have a great one!
Morning Bob and others,
Danno, how about an update on the recovery?
Meeting some friends for lunch this afternoon. Then back to the house for some train time.
Have a great day ya'll.
From photo programmer -
Jim Donovan
Morning Folks;
Dan, I join the group in saying ,'hope you are well and getting better'. Curt I hope you too are getting better, you are dealing with very difficult times.
For me, it is just another Saturday, the way I like it. I need to do some cleaning and fixing then hopefully some play time on layout.
Have a great day.
Jim D
Holland & Odessa Railroad
Good Morning All,
I  would like to thank everyone for your condolences, prayers and kind words.  It really means a lot to me.
Today I'll be doing yard work that I have been putting off for too long. I'm sure I will enjoy the temps and humidity.
MartyO
Morning,
Blue skies ... enough said.
Marty
Morning ramblers!
Got a big deadline tomorrow, so will be working much of today to meet that.
Hope you all have a great one.
Morning,
Late check in today...
Chance of rain...hope is shows up...we need it...
Tommy
Well, this morning (instead of spending time on the exercise machine) I went back to the last switch machine (the one that's far away) and checked the frog polarity.  Of course, it was wrong, so I reversed the wires.  That's when I found a short (frog was getting power from one rail regardless of point position/relay setting.)  I found a spike that was probably causing the problem, removed it, and the problem remained.  So I futzed with the wiring, removing and reinstalling wires, and eventually the problem fixed itself.  Hopefully this problem won't return!  (See https://en.wikipedia.org/wiki/Heisenbug for a good technical term you can throw out when debugging wiring...)
The next step is to add the switch machine power feeds (from the Tam Valley 12v to 5v conversion board.)  One difference between the Tam Valley and Walthers servo turnout motors is power source.  Walthers must do the 12v to 5v conversion on the switch machine board.  This means more custom jumper cable construction, along with some time underneath the layout to connect things.  What a rat's nest of wiring!  (This is the most complex part of the layout from a wiring/turnout perspective, with lots of both standard and narrow gauge turnouts in close proximity.)
Well..... by now............ afternoon all..........
Two great photos today.......
For Tom Langford's post............   The Chevrolet trucks a really cool. Where was that photo taken.  That structure has some possibilities.  Looks a lot like a modified  Campbell Brice Mills kit as a starting point.
For the other Tom........  I have not seen an end opening box like that.  The doors are sure beat up.
Thanx  all
Good afternoon. I just returned from the Northern Hqtrs.  It's time to do some modeling.  Dan I hope you are doing well with your recovery.  Positive thoughts and prayers coming your way.
I hope everyone is having a great day.
Update on Dan:
I just talked to Raymo by way of txt messages.  He is home and doing well, considering all the work he had done.  Dealing with the many affects of post op but, doing okay. He is managing the pain with some good drugs. :o ::)  He told me to tell everyone hi and that he will be back on the forum soon.
Continued well wishes, thoughts and prayers Raymo.
