Friday - August 27, 2021
Started by ReadingBob, August 27, 2021, 07:01:01 AM
A dry cold front is due in later today.  The last couple of days here have been pretty nasty (hot and quite humid.)  Fortunately the basement stays pretty cool, even if the dehumidifier is running constantly.
I've been cutting fillers between the tracks in my visible staging yard (so I can ballast that yard without wasting a lot of ballast to fill in between the tracks) and working on a laser cut boxcar kit.  It's good to have a couple projects going in parallel, I can work on the car when the paint (primer) is drying on the foam fillers, and let the glue dry on the boxcar when I install the next set of filler pieces.
jrmueller
Good job Dan. You're doing better than I did 16 years ago. The surgical procedure has improved significantly. Jim
Jim Mueller
Superintendent(Retired)
