Fos Execution Rocks
Started by madharry, August 08, 2014, 05:25:03 PM
Quote from: madharry on August 09, 2014, 12:50:56 PM
Adding shingles to the four mansard roof sides is next.
I have found the instructions a little hazy here. They state "add the four mansard sides, test fit before gluing, do not worry about gaps as they will be covered by roofing - glue them in place".
I have decided to try a different approach. I have used sellotape to affix the four mansard sides together and I intend shingling these flat on the workbench before gluing the complete assembly to the roof............wish me luck!
Mike  - this will be fun to watch - Good luck!
Hi Mike:
Looks like you are moving right along. Does this have a place on your layout? If so don't forget to post some photos OK.
Mike,
Looks like it's coming together very nicely. Thanks for all the photos.
madharry
Thanks John, the roof is almost finished - update pictures soon.
madharry
Thanks for your comments Karl, I'm planning to put this together with some other kits on a small module as a mini-show layout.
madharry
Thanks for following along Tom. I hope to get a lot more done this coming weekend!
Mike  ;)
madharry
The main roof is now shingled and next up is the completion of the tower roof.
madharry
I started by gluing the first two (of four) gable ends to the top of the tower cap.
Next...........I added a brace of wood between the walls and tried dry fitting the roof between the walls. However I think I may have to cut down the roof in order to fit the two remaining gable ends which are to be glued where my thumb and finger are!!!
madharry
Continuing... I decided to modify the roof to fit.
Then I strayed from the instructions and decided to shingle the roofs before gluing them to the gables. I used double sided tape.
madharry
Continuing............ before I started shingling I painted the edges of the roofs white. Once I had finished the larger roof I glued it between the gables before shingling the smaller roofs in the same way. I think this is an easier method than gluing the roofs down first and then shingling them in situ........
I'm really enjoying the thread.
madharry
Thanks for following John.
Mike  :)
madharry
Continuing......... I finished tiling the small roof. I laid the tiles overlong on the double sided tape and then trimmed with a blade.
Afterwards I glued this to the assembly.
I then added the trim pieces to the gables after painting them white. I also added two pieces of paper to form a ridge cap.
The instructions called for this all to be done with the cap glued to the building. I found this way easier.
Mike Carter
madharry
Continuing...
These are the parts for the ten dormers.........I have painted and glazed the windows and painted the walls.
I might stray from the instructiions which suggest gluing each dormer to the main roof before tiling the ten individual dormer roofs........ :?:  :?:
jrmueller
I am enjoying watch you progress with this project.  although I have no plans to build it, I am learning various techniques from you.  Thanks. Jim
Jim Mueller
Superintendent(Retired)
