Inter-Action Hobbies 17' Travel trailer build
Started by ACL1504, September 14, 2024, 01:29:49 PM
I think this is an excellent kit to build. It is tricky in some areas of the build. However, you follow Darryl's instructions, you'll have no problem in the construction.
I have a tendency to over build a kit with my own spin on how I want it to look.
If you are considering purchasing and building this kit, I strongly suggest you use extra bracing on the floor and top to help keep the walls square. I found this very helpful when adding the roof skin. The top bracing kept me from pinching the top of the walls inward as I was gluing on the roof.
I opted not to add the red stripe around it as I like the full aluminum look. This is a kit/model you don't see on many layouts.
Here is where mine is for now.
Very nice little scene...it certainly fits your locale. Nice job!
Nice work on what looks like a fun kit to put together.  Fits in your scene perfectly.
That came out wonderful and looks great in its new home.  Kudos to both you and Darryl!
Rail and Tie
That turned out to be a very clean build. Well done.
Darryl Jacobs
www.interactionhobbies.com
Nice work and model Tom! Looks a bit like the old 50's Shasta trailers.
Quote from: cuse on September 26, 2024, 02:20:11 PMVery nice little scene...it certainly fits your locale. Nice job!
Thanks very much Butty. Its right at home under the oak tree.
Quote from: Zephyrus52246 on September 27, 2024, 08:43:51 AMNice work on what looks like a fun kit to put together.  Fits in your scene perfectly.
Thank you and it was very much a fun build.
Quote from: ReadingBob on September 27, 2024, 09:52:48 AMThat came out wonderful and looks great in its new home.  Kudos to both you and Darryl!
Thank you, the credit goes to Darryl. Without him there would be no trailer.
Quote from: GPdemayo on September 27, 2024, 01:51:08 PMWell done Tom, it looks great in place.  8)
Greg,
Thank you and don't you dare try to move it.  ;D
Quote from: Rail and Tie on January 04, 2025, 10:41:30 PMThat turned out to be a very clean build. Well done.
Darryl,
Thank you kind sir. I really liked building it. Now I need to try a couple of your trucks.
The Gulf/Sinclair Gas Station was a fantastic build and kit.
Quote from: Philip on January 05, 2025, 08:02:48 AMNice work and model Tom! Looks a bit like the old 50's Shasta trailers.
Philip,
Thank you, much appreciate you stopping by. I agree, it does.
