FSM Jeffries Point Build
Here we are a month and a half later.   ::)  Using the original stair landing templates, I made the railings in place before adding them to the stairs.  The drawing on the left I used to make the lower stair railings on the template and added them afterwards.  I then added the awning over the door/upper landing.
Next up was the awning for the door on the back of the building.  I also reattached the loading dock stairs that got knocked off sometime I was working with the stairs.
Finally the front awning was build and added.  Then the guywire supports.  I use some NBW castings where they come out of the building instead of just gluing them on.  A hole is drilled into the building and then the NBW is slipped on and it's pushed thru.  I pre bent and cut all three to the same size before installation.  I also use the NBW castings on the outside shade lights where the wire goes into the building.  Except for the roof signs, I think the actual building is complete.  I haven't decided whether to change the sign or not.  There is still and outhouse to add and the details, but I can move the building off the workbench for now, before getting all those things painted.
Howdy Jeff,
Nice work on the awning and stairs.  I'd love to see a close-up of the NBW and guywire supports. It looks like an excellent solution for attaching wires to a structure.
Excellent job on the stairs Jeff. The whole structure looks awesome.
Hello Jeff, I agree with Curt, your build is very impressive, some very fine modeling to be sure.
Jeff you hit this one out of the park.  Beautiful work!!
Looks great, Jeff.
Thanks for sharing your journey with us.
Ensign
Jeff, I am more than a little late to be commenting on your wonderful build of this classic FSM's kit.
However I must say you've done an amazing job of bringing your kit to life!
I really like the green colour that you painted your walls, gives it a completely different look from the really weathered & rundown version that George has built of this structure on his layout.
Greg
Thanks, Mike.  After posting, I noticed they were hardly visible.  Here's a pic of the guywires and a light fixture that have the castings where they attach to the wall. .  The guywires are actually close in color to the NBWs, in the picture the middle one looks green.   :o
Thanks for looking in, Philip.
Curt, they were a real pain to do.  Thanks for the compliment.
Jerry, there were some times I wanted to hit those stairs out of the park with a bat.  Thanks.
Hi, Mark.  It's been a long journey.  Too long.  Getting near the end finally.
