It is looking great Dave!
Oh no organization  ;)
Something I'm unable to achieve.
Today's project, Dudes!  (My brother's kid, when he was little, called his action figures his 'dudes'.)
I still need to finish face, hair and shoes, and maybe redo hats.  But the clothing is done.
It's nice to know I still have that fine motor skill.....
Excellent job on the little people Dave.
Progress on my scratchbuilt pipe threader:
One problem is the step pulley is heavy, making this lopsided.  I'll need to add some weight on the near side to keep this from flopping over once I put the legs on it.  I also need to add some more details.  The brass hand wheel is an O Scale brake wheel.   This will handle 6" diameter pipe, which is not bad for an oil country repair shop.
Howdy Dave,
The little people are looking good.  That's tedious work well rewarded.  The pipe threader is amazing. I can't wait to see it finished.
I still need to do a bit of clean-up and add back a missing handwheel, but this should be done:
The legs are heavier than I originally wanted, but they're necessary to keep this from tipping over.  Even with the lead strip counterbalances and the lighter/smaller cone pulley, this still tends to lean to that side.
craftsmankits
Keep up the good work. I've been following along.  Looking forward to seeing the machines set in place along with the belt drives and assorted details.  Mark
The pipe threader is done. I reworked the stand, building a jig to assemble it.
John Siekirk complained there was no support for the cone pulley.  That actually made sense to me.
I added a handle on the large (brass) hand wheel.  It's a busy day tomorrow, so Tuesday this should go into the paint shop.
The end result isn't as delicate as I would have wanted, particularly the stand.  It was the usual compromise between size and strength...
Dave, little people look good.
That's some good fabrication work on that pipe threader.
I'm calling the pipe threader "done".
It's a bit crude viewed this closely, but at normal viewing distance in the machine shop, it should look fine.  Now since that detour is done, I should get back to the rest of the building.
For HO I think it looks pretty dam good Dave!
KentuckySouthern
