Jerry,
Impeccable work as per your usual standards.  Colouring looks great.
Quote from: Zephyrus52246 on January 28, 2026, 04:47:07 PMI didn't know you could use mineral spirits with the chalks instead of alcohol.  Thanks for the tip.
The Rembrandt chalks use clay as a binder hence the use of mineral spirits
Jeff, Curt, Rick, Ron & Philip.
Thanks for all the wonderful comments!  Believe me it's greatly appreciated knowing you all took the time to post.
Hell Ron I never knew that was why you could use it thanks for telling us.
And Rick there will always be a Schintzler Pond my friend.
I guess I should draw up a plan on the buildings that are going to be on this diorama.
Once again thank you all.
Howdy Jerry,
I thought Schnitzler's Pond had dried up!  ;)
Nice job with the chalks and mineral spirits.  The wall color looks realistic.  I love all the fire stops.
Glad to see you back on this fun project.  I'm looking forward to the build.
Thanks Mike glad you liked it.
The pond will never run dry!!  :)
I'm glad to see you back at this again, Jerry.
Your framing is always the best and superb!
Looking forward to more.
Thanks Rich hopefully the deep freeze will go away and I can back in my room.
Just so you know I was really working on framing that second wall.
So now it will be doing the outside sheathing and I'm not sure if I want to tarpaper the inside.
And to make a jig for making the windows.
Jerry, as usual, your framing is excellent.
Jerry,
Framing is perfect and looks like a 1:1 frame job shrunk to HO scale. Expertly done.
"Honey, I shrunk the framing!"
Jerry I can only echo what the other's have already stated; fantastic job.
Jerry,
2 walls down and 2 to go.  ;D   The walls look great and the colouring is spot on.
Curt, Rick, Tom, Larry & Ron.
Thank you for the wonderful comments.
On to the siding.
