Path Valley Lines
Started by VagelK, September 03, 2025, 06:36:07 PM
The layout looks awesome Vagel.
VagelK
Thanks, Curt.  Wifey mentioned the other day that I seem to be more motivated to spend time at the layout, because it's become such a pleasant environment after almost two years of 1-2 hours a day of "work."  There's something to be said for that.
This segment will follow the B&SGE's Buchanan Branch to its terminus in the real-world place called Cowans Gap.  Emerging from behind the blast furnace complex the branch climbs a 3% grade on a sweeping curve butting up against the backdrop.  B.S. (before scenery) the clearance diagram allowed the largest loco's (K27 2-8-2's) to pass, but the addition of a 1/2" thick foam shale cut above the overpasses reduced that to the little C19 2-8-0's.  Fortunately they are powerful enough to haul the empty ore cars and other local traffic up the grade - but no continuous runs for anything bigger during open houses.
The track comes off the curve to pass behind a mountainside that is only about 3" deep but is designed to give the impression that the branch dives into the mountains.  The section with hand carved rockface is removable for track cleaning.  I promise to someday continue the rock work on the rest of the mountainside... honest.
That crazy train on the PRR, by the way, is not something that gets run during ops sessions; it's my NMRA collectibles train run for visitors from time to time.  The caboose is a Western Maryland prototype in 1970s Chessie livery; it reminded me of my days as a kid waiting for the morning drag out of Hagerstown, MD to pass thru Chambersburg on my way to high school ... which meant that I would be late for homeroom!
The tall trestle and the road overpasses below it are the work of the late-Don Reed.
Not far above the trestle the branch enters the village of Buchanan, which exists because of the So. Penn Furnace Co's iron ore mine and processing plant.  The village, itself, is represented by the dome of the Russian Orthodox church poking above the woodline (based on the one in the former coal company town of Woodvale on the E.B.T.) and a printed image of company houses pasted to the backdrop visible through the draw behind the mule barn.
That little red barn is a basswood kit by Webster Classic Models, and the tipple/processing plant is the Walthers Glacier Gravel kit, with conveyors repurposed somewhat.  The depot is a kit for the E.B.T.'s long-gone depot at Coles, while the enclosed water tank across the tracks is another Tom Middleton scratchbuild of the one at the same location on the E.B.T.
The two tracks converge just beyond the waste conveyor to pass through a hole in the wall disguised by a deep rock cut and tree tunnel ...
... to emerge at Cowans Gap, the end of the branch and site of another, smaller iron ore mine.
By the way, Buchanan gets its name from the PA state forest of the same name, which in this era (1930s) is being planted by the Civilian Conservation Corps - one of whose camps is just off-scene to the right of the ore tipple.  From left to right, the covered bridge is the snap-fit Walthers offering, the store is another of those structures scratch-built by someone else for sale at a train show in the misty past, the depot is a JL Innovative Designs McDougall Telegraph Office that I modified with wooden shingles, brick chimney, and other details, and the tipple is cobbled together from pieces left over from the Glacier Gravel kit and Evergreen styrene siding, with scratch-built walkway and railing.
Camp S-54 houses the young men who are planting in this area and building the future Cowans Gap State Park.  It receives occasional shipments via the stub of the Kalbach Branch (a remnant of the logging RR of the Kalbach Lumber Co. that clear-cut this area in the early-1900s, thus the CCC being here); the Kalbach Branch passes through another hole in the wall to enter hidden trackage that reappears at the other end of the modeled B&SGE (Tuscarora Valley Jct).
That's it for this entry.  Next time I'll backtrack to the Richmond Furnace area and the PRR's piece of the operation there.
The covered bridge works great as a view block, it fits the location.
Great layout shots Vagel. You've done an excellent job on the backdrop. It has a great depth of view to it.
VagelK
Thanks, Dave and Curt.  I got the backdrop technique from a series of posts on RR-line; the guy was building a layout set in West Virginia during Autumn, and he had developed a pallet list of the tube acrylic paint colors that matched the shades of Woodland Scenics coarse ground foams.  He also had in-progress pictures and how-to's on how to use sea sponges to dab on the paint.  It was a revelation!  I painted my backdrops about 3-4 linear feet at a time.  I should look thru my archived posts from way back then to try and find the "recipe" ...
Quote from: VagelK on September 23, 2025, 12:43:01 PMThanks, Dave and Curt.  I got the backdrop technique from a series of posts on RR-line; the guy was building a layout set in West Virginia during Autumn, and he had developed a pallet list of the tube acrylic paint colors that matched the shades of Woodland Scenics coarse ground foams.  He also had in-progress pictures and how-to's on how to use sea sponges to dab on the paint.  It was a revelation!  I painted my backdrops about 3-4 linear feet at a time.  I should look thru my archived posts from way back then to try and find the "recipe" ...
Was that Coaltrain who your speaking of? Great layout you have!
VagelK
Quote from: Philip on October 15, 2025, 09:36:11 AMWas that Coaltrain who your speaking of? Great layout you have!
I don't recall, Philip.  It was so long ago, and he just dropped out.
Yeah it has been awhile.
I don't know how I keep missing your updates?
That is a fine looking layout you have there!
VagelK
Quote from: Jerry on October 21, 2025, 10:18:45 AMI don't know how I keep missing your updates?
Thanks, Jerry.  I've been quiet for several weeks; camping trip, other stuff.  Probably be early Dec. before I can get back at working on the RR.
