Hank's Machine Shop
Rich and Curt thank you both so much.
Yup you guessed it.....more details:
This is a little "make shift" bench sitting on top of two stacks of wood blocks. Theses were a few of the details that I acquired from Jerry awhile back; may as well put them to good use. The box of metal parts and a couple of other metal parts on the bench were colored with gun metal paint. Everything thing else was colored with chalks and clear alcohol. The bench was weathered with black powder.
Another view of the same bench.
Her's a wooden barrel with more metal parts inside and an old washtub with even more metal parts. Theses were colored in the same fashion as the bench.
So if you put all the details together you have what the left hand side and back corner will look like; of course nothing is glue in place until after the walls are detailed. I needed something for the corner so I went through the parts boxes and came up with a 50 gal. drum and a few 25 gallon ones to help fill the corner and another small drum with a propane tank sitting on top. Added a broom, have to be somewhat neat in the Shop, as well as a trash can filled with discarded metal parts.
Now it's onto details for the right hand and the back floor areas before starting on the actual walls themselves. I already have the four machines and they will come later but they do fit to give me the look I'm going after. Thank you for following along and for all your great comments and/or suggestions. Stay tuned.
They look great. You should come here and paint mine!
labdad
Good stuff!
Devils in the details!
 ;D
MJinTN
New details look very good!
Larry a great job on those details!!
Curt, Mj, Rick, and Jerry thank you guys for your kind comments.
Curt not sure if I could even do HO sized details; those are really small.
kyle creel
Goodness Gracious :o  ;D Larry C*,.....where to begin ::) OK......IT ALL LOOKS SOOO DANG GREAT!!! ;D  ;D  ;D  ;D.....how 'bout this :o ....I'll trade you 90% of my backdrop skills (I still have to finish my backdrop) ;D  for 1% of your 'details' skill??? :o  :o;....I love your work my man........... ;)  8)  8)  8)  8)
KYLE CREEL
G&D Ry Co.
Kyle thank you for your kind comments; they are really appreciated. The swap sounds good to me.
Philip thanks; much appreciated.
Did somebody say details?
A couple more details colored then weathered with just a hint of rust to kick back the gun metal paint on the metal items.
Here's a couple more small details. The metal old wash tub was colored to look like an old tub. Had scale coal left over from the Blacksmith's Shop so that was added. The barrel has a wooden box on top with a wrench inside. The barrel had the bands colored with a black pencil so they'd show up better.
This is a large parts bin from Rusty Rail. This one gave me fits. First I had to sand the crap out of the back to get it to sit properly. Then the cabinet was colored using chalks and clear alcohol. After that the little metal details inside were painted with gun metal. When dried the entire cabinet was weathered with chalks.
This is where the cabinet sits at the moment but that may change. Also the cement pad, which will have a potbellied stove on top, was cut from picture framing mat and spray painted grey. One thing I neglected to mention is the "glass" in the windows is acetate sprayed with a cheap hairspray to look dirty. So this is where I'm at for the moment. As always thanks for stopping by for a peek and for all your great comments and/or suggestions; stay tuned.
Howdy Larry,
Nice work on the details.  The colors and placement look great.
BTW, the images in your last post didn't load.
Mike thank you so much and I'll check into the previous post concerning the photos.
