1907 Scherzer Rolling Lift Bridge CAD designed and 3D Printed
Started by Jim Donovan, November 11, 2025, 08:53:36 PM
Jim Donovan
Quote from: Bernd on March 20, 2026, 09:03:57 AMJim,
That looks very nice. It be really would be neat to have an etched brass version and make it actually function.
Bernd
Thanks Bernd.  think this could be made better and actually function using mostly 3D printing. I'd need to use ABS resin and the motor gear assembly definitely at least brass. Perhaps sometime in future I will look at again.
Holland & Odessa Railroad
Jim Donovan
Quote from: Jerry on March 20, 2026, 11:21:42 AMJim an outstanding model.
Jerry thanks I think overall it will fit in just fine on the layout. I have dropped the section into its layout slot and will pour the 'water' when all fitted together.
Jim Donovan
Jim Donovan
Quote from: jbvb on March 20, 2026, 05:04:47 PMRegardless of the problems you encountered, you've got an extremely unique and detailed model there.  I wonder if epoxy's curing time would have helped?  It certainly would have slowed down the job.
Thanks and you had the same thought I had after building this, epoxy glue would most likely work much better and I am going to try it next resin project. I would rather have the set up time to work with than getting things together quickly.
Jim Donovan
Quote from: elwoodblues on March 20, 2026, 07:42:27 PMJim,
I can see the issues you had with the printing process, but that was only after taking a second look at it very carefully.  With the issues you stated a think you did a great job overcoming them and you should be proud of the result.  I hate to say this but a lot of people would have given up instead of persevering.  I for one would be honoured to have that bridge on my layout.
Very well done.
Ron thank you appreciate the comments. I try to improve project by project and this one just had a lot of moving parts but it will work fine where it is being placed and who knows I might take another crack at it down the road. I learned a lot from first attempt. I am posting a photo of where it is going.
Jim Donovan
Quote from: Zephyrus52246 on March 20, 2026, 08:06:57 PMI think the bridge looks great.  A nice scene with the bridge keeper's hut, too.
Thanks Jeff, I am in the middle of redoing the shed as I cracked a wall plus the camera shows too many warts. Easy fix for that and the plans were actually part of the diagrams for one of the bridges I used as prototypes, it is the shed used for the Monroe street bridge in Toledo.
Jim Donovan
Thank you to everyone that followed along and commented on this project. I appreciate the comments and ideas offered. The bridge is in its place just needing to be 'filled in' to the surrounding scene. So here is where it will be:
Thanks for following along.
That fits nicely!  The canal makes it clear why a short lift bridge is appropriate in that location.
Jim that's quite an impressive looking bridge; very well done and really adds interest to the scene.
Jim,
The bridge fits in like it it has already been there for years.
Jim Donovan
Well;
After a week of looking at the bridge I decided I needed to fix what was wrong, which meant I would need to do a complete redo. Fortunity with the CAD drawings it was not like starting from scratch. I fixed the out of 'square' issue by printing the main frame as one piece and then adding the various truss plates, cross members, wood floor and so on piece by piece. The result is a more prototype correct version that is square and if automated would trac true as it lifted. I learned a lot on this redo so when I get to the train lift bridge I am sure I can animated it. I don't think I did anything in the resin printing that was unique to this version so I am just posting final photos. In the photos you will see the control shed rebuilt so it is much cleaner looking and even is lighted by a table lamp on the desk. Also I 3D printed a 3 story resin building across the canal that is a pub on the first floor and offers more 'hands on' entertainment on the second floor. It will have a complete interior. I may publish how it was made but that is another day. Hope you like the revised version.
Bridge Side All Lite and tunnel.jpegFront Bridge with Paul's.jpegGood Bridge Back Lighted.jpegGood Bridge From Rear.jpeg
Jim Donovan
Jim Donovan
This version looks good. What are the length, width and height  from the top of the piers?
