CCK Doc Koontz Build
I then used a sanding stick, first on the rough side and then on the fine side.
The rough side removed the rest of the tab and then I sanded it flush with the fine side of the sanding stick.
This worked very well and neither part was damaged. I believe holding the frames and then using the sanding stick had the potential of creating a disaster.
All these window parts are fragile.
The photo below shows the two inner window frames sanded smooth and flush at the top and bottom.
I'll have more tomorrow. Done for today.
Tom, your experiences and work arounds will be very valuable to any else wanting to build this kit.
Tom nice techniques to get a great end result.
Quote from: Rick on December 16, 2025, 07:21:29 PMTom, your experiences and work arounds will be very valuable to any else wanting to build this kit.
Good statement Rick, and to anyone else probably working on a similar kit with bay windows.
And great informative s-b-s from you, Tom, especially showing all the fixes and expert construction principles.
You keep impressing us with your technique Tom.
Tom that is really an impressive window.  Very well done.
Like Rick said it will help anyone who is building this kit.
Nice work on those tiny mullions  :o
Howdy Tom,
That is amazing work on Koontz.  The windows, doors, etc look amazing.
Rick,
Thank you. I've never seen this kit built on either forum. Not sure how many he sold or, if any were built.
Hopefully, it searched, this may help.
Quote from: Larry C on December 16, 2025, 08:20:18 PMTom nice techniques to get a great end result.
Larry,
Thank you, it has been a challenge for sure.
Quote from: Pennman on December 16, 2025, 09:38:56 PM
Rich,
Thank you for the comment and for your support.
Quote from: PRR Modeler on December 17, 2025, 06:45:49 AMYou keep impressing us with your technique Tom.
Ah, shucks, I'm fiddling my way through it.
Quote from: Jerry on December 17, 2025, 08:57:50 AMTom that is really an impressive window.  Very well done.
Jerry,
Thank you. I agree and the two bay windows really changes the look of the building.
Quote from: Philip on December 17, 2025, 09:19:23 AMNice work on those tiny mullions  :o
Philip,
Thank you kind sir, much appreciated.
