2025-2026 Winter Challenge Interlocking Tower Build
Started by Zephyrus52246, January 20, 2026, 04:40:07 PM
Mixed the Polly Scale with water, 50/50 or so with a couple of drops of airbrush Flo Aid.  did two coats.  Forgot to mention, I didn't leave on the carrier sheet so I could paint all the edges. Only spilled a little paint on myself.
I have a new Grex Airbrush which the sales guy at the Narrow Gauge Convention stated didn't really need a "total break down cleaning" very often.  We'll see if it works.
They came out OK.
I also put a coat of the Depot Buff on the siding.  Used a wide brush and occasionally dipped the tip of the brush in water to more evenly spread the paint.  They look a little rougher than the picture shows and may need a second coat.  I'll compare them to the station and see.
Unfortunately, I was worried the Roof Brown wasn't dark enough and the trim piece shows this to be the case.  I'll see if I have a darker brown in the Vallejo set.  I must have used a different brown on the station, or maybe this brown is lighter than the original Floquil solvent paint.
Jeff looks like you're off to a good start. Hope the railing aren't as fragile as they look.
Very nice spray job and window construction.
Jeff, glad you were able to get the windows together.
How do you like the airbrush?
Hope you find a darker brown.
Howdy Jeff,
I concur with the peel-n-stick stuff.  It's always a challenge. Hope you like the airbrush. You might be able to darken the paint with pigments.
Jeff chocolate brown is a good trim color with buff. Good progress so far.
Larry, they do look very fragile, I'm sure I'll manage to break one somewhere along the line.
Thanks, Tom.  The airbrushing went well, except for the color issue.  I'm more concerned with the window installation in the siding.  There's not a lot of contact point for attaching them.  We'll see how it goes.
Rick, the airbrush worked great.  It's a GREX model.  it has a pistol grip trigger instead of one on top like my Iwata.  It's much easier to control the paint flow.  We'll see how it works today as I didn't do a "tear down" cleaning after using it yesterday.
Howdy, Mike.
I think I'll just overpaint the trim instead of trying to use pigments.  I may not have a good color match and usually end up making a mess with them, though I could try the pigment/alcohol "painting" method.
Thanks for watching, Curt.  I have several dark browns here with the Vallejo paints.  Chocolate brown is one of them, hopefully a closer match.
I never had much luck with the "peel & stick" over time so I always add a bit of thin ACC to reinforce the glue joint.  The build is coming along nicely, hope you get the colour issue figured out easily.
I put this one together about 16 years ago Jeff and was happy with the results.
Have fun and i'll be looking in..... :)
Nice progress, Jeff.
I'm watching with interest.
