2025-2026 Winter Challenge Interlocking Tower Build
Started by Zephyrus52246, January 20, 2026, 04:40:07 PM
Thanks for looking in, Greg and Mark.
Ron, thanks.  I think I got the color figured out.  Tried five different Vallejo colors and a Delta Ceramcoat as well.  Of course the Delta was the closest match.  It's the one on the stringer next to the cigar sign.  I did a second coat of the Depot Buff on the sides and will add a third to more closely match the station.
Also a picture of the Grex airbrush.  I will brush paint the Delta paint.  I have airbrushed some of these in the past, but they have to be so thin they get kinda watery for me and don't cover well.
Michael Hohn
You're using a classic pair of colors.  They always look historically-appropriate and railroady.
Jeff picking color combinations is almost an art form trying to get the correct match with what you have in mind. Nice looking airbrush.
Thanks, Mike.  The station is painted per George Sellios' instructions, it's an FSM kit.  The first I bought way back when.
Larry, when I build a structure, I always overthink the color scheme.  I usually go with what the manufacturer used, unless it's a CB&Q structure, then I use appropriate company colors.  I tried to find Rock Island colors, and they used a buff and brown/maroon color scheme, which is similar to this.  I did want to make it match the station if they end up being "paired" on the layout.
What are the CB&Q colors. Are they the same as the challenge build?
They are "Bronze Green" and "Indian Red", like on the tower I used as a placeholder example.
Jeff nice looking little build; should look great on your layout.
KentuckySouthern
#55
Nice!
Thanks, guys.  I built that tower a few years ago.  I have another kit for it to use in another spot on the layout.
I'm doing things in a different order than the instructions note. They have you assemble the tower first. I wanted to do most of the work with the sides flat on the work bench.  First I added some board cuts and nail holes.  I have a tool I think from England to make the nail holes.  they are finer than the usual pounce wheels.  I then use the "Monster Nailer" to make two holes on each side of the board cuts.  I didn't lift or remove any boards as the tower is well maintained.
I then added the window frames.  I will then use an oil paint/thinner dark wash over everything.  Doing this before putting in the window glass will make sure I don't stain the glass by accident.  It will then be easier to add the glass when the pieces are flat on the bench, versus the sides being together.  I did use a small amount of Elmer's glue (the Titebond sets up too fast) inside the window frames as some of the sticky side stuff came off on the tape when I removed them.
Great looking progress Jeff. It's a smart idea to do the glass before assembling the walls.
