Blacksmith Shop
Philip,
Even though I haven't been present much, your build is still within my thoughts.
You have accomplished great strides with this construction, looks great.
Thank Rich! Hope your doing well!
Moving forward a bit.
That roof looks spectacular!
Philip the roofing looks like it's been in the weather for a good bit of time. Very well done.
Thank you both!
The dormers are all cut in. Now the other side awaits...
Easy straight run on the other side.
I wasted a bunch of shingles on the angles.. Once the tin is down I'll make all the caps and finish trim the windows. I think I'll tar seal it all. Black RTV works pretty good.
Done for the day!
Howdy Philip, WOW.  ~mike
Philip that has to be one of the BEST model metal roofs I've ever seen!!!!!!!!!!! Extremely well done.
Quote from: Larry C on July 20, 2026, 07:33:05 AMPhilip that has to be one of the BEST model metal roofs I've ever seen!!!!!!!!!!! Extremely well done.
ah.. hardly but still a BIG thank you! 8)
Philip, the etchant did a great job on the roof.
I don't think you can buy that stuff any more.
Or can you?
Thanks Rick! Ferric chloride is still available....somehow :o ! I still have some from Micro mark but running low.
Todays activity Now to get after those windows and make some window pains ;D  aka panes.
Philip I think you had it right the first time....window Pains....but I'm sure you'll figure it out.
Philip that is a great roof nice coloring.
