SW Shipyard at Foss Landing
Started by PRR Modeler, June 11, 2026, 12:04:58 PM
Curt great job on the saw shed and I agree with Rick the roof looks overdone.
Curt great job on the decks.
The roof looks a little bit to cooked like Rick said.
Afternoon All,
Thanks for following along and your comments Rick, Larry and Jerry.
I actually looked at images of old tin roofs next to salt water and there are a few examples of what I did so that was my reasoning for the roofing.
Quote from: PRR Modeler on September 21, 2026, 12:07:31 PMAfternoon All,
Ahh. I stand corrected.
Morning All,
Initial layout of components on one of the foam bases. The yellowish brown items (3) are resin sea walls. I did not put the warehouse/office on for the photo to see where the platforms go.
Curt that looks to be quite a large diorama. The areas that are NOT water going to be elevated at all?
Just curious.
That is definitely going to be a big diorama.
Nice to see it starting to come together.
Yannis
Excellent work so far, many thanks for sharing.
Good Morning,
Thank you Larry, Rick, and Yannis for following along and your kind words.
The large platform at the top of the photo will be over water as will the bottom dock with the shed on it. It will also have a crane mounted on it.
The big gap with nothing in it is where the ship under construction will sit and the area will have an incline into the water.
The rest will be flat ground but I plan on seeing if I can make a small hill after I figure out roads and paths.
Anyway that's the plan.
Howdy Curt,
The layout of the scene looks good. I can't wait to see it all together. The remaining structures promise to be amazing.
Curt your doing a wonderful job on this.
Really looking forward to the next update.
Afternoon All,
Thank you for following along Mike and Jerry and for your kind comments.
This is a quick progress report. There is a lot to do yet on the boat. I just put the keel on the diorama to give an idea of what it will look like.
The only things permanently attached at this point are the seawalls and foundation of the warehouse.
Curt your diorama is coming together nicely! Looking forward to seeing you progress.
Afternoon All,
Larry thanks for following along and your kind words.
Another short update. The ribs and cross beams have been added to the keel.
Curt that is looking excellent!!!! Great job. You really need a kit with instructions to build even this much of a boat under construction. I tried to scratch build something similar and it was an utter disaster.
