kyle creel
WOW RON :o  :o  :o  :o ..........I just went through your entire story/instruction photo/essay... :o  :o  :o  :o ....What a fantastic job ;D  ;) ... it's truly amazing to me how ya'll build this stuff.....I haven't any of the tools, or weights or clamps- (I've always just used CA)- or anything else that's needed to build one of these kits..the only kits I've ever even attempted were plastic ;D  ;D  ;D :o ....so I'm absolutely floored by what ya'll build......such beautiful work...WAY, WAY ABOVE MY PAY GRADE  ;D  ;D  ;D  ;D ......fine work indeed.......
KYLE CREEL
IMMR & T Co.
Quote from: kyle creel on August 03, 2026, 12:47:24 PMWOW RON :o  :o  :o  :o ..........I just went through your entire story/instruction photo/essay... :o  :o  :o  :o ....What a fantastic job ;D  ;) ... it's truly amazing to me how ya'll build this stuff.....I haven't any of the tools, or weights or clamps- (I've always just used CA)- or anything else that's needed to build one of these kits..the only kits I've ever even attempted were plastic ;D  ;D  ;D :o ....so I'm absolutely floored by what ya'll build......such beautiful work...WAY, WAY ABOVE MY PAY GRADE  ;D  ;D  ;D  ;D ......fine work indeed.......
KYLE CREEL
IMMR & T Co.
Kyle, this kit would be well within your abilities.  It goes together well.  There are a lot of steps, but the instructions are very good.
KYLE CREEL
IMMR & T Co.
Kyle, Thank you very much and there is nothing wrong with plastic  ;D
If you ever decide to try a wood kit, I would definitely recommend it.  You really don't need all the fancy tools to build this kit, I use them because I have them.  ;D
Quote from: deemery on August 03, 2026, 03:01:08 PM
KYLE CREEL
IMMR & T Co.
Kyle, I agree with Dave.
Thanks Dave, there is a lot of inspiration in that photo.
Time for another update, The dreaded
Part 13 - Nuts and washers
So, these are the pieces required to make the nuts, bolts and washers required for the attachment of the stringers to the bridge ties. :o  The instructions state "Go get an enormous mug of the strongest coffee you can find.  You are going to need it for this bit!"  Forget the coffee I would need a bottle of scotch for this step.  :o :o :o   The instructions also state that he had planned to use Grandt Line casting but due to supply chain problems would have caused manufacturing delays.
The only parts I plan to use are the base plates which I assumed would be steel so I painted them "light Rust" (Vallejo's Panzer Aces #301)
These are the NBW castings I used instead of making my own.  These are Tichy's castings, 4.5" washer, 2.5" Hex nut (#8270)
The base plates glued to the stringers on the first half of the bridge.
Gluing of the base plates completed.
The NBW castings glued to the first half of the bridge.
The rest of the NBW's glued in place.  I used thin CA for this step.
I will admit that using the NBW castings did not required any scotch to carry out this task, but one was has to celebrate a job well done.  :D
'Fess up, Ron.  How many NBWs did you lose in this process?   ;D
Ron having to assemble ALL those NBW's would have taken the "hernia size" bottle of Scotch. Great job and it looks terrific; it'll look great when installed.
That's a great looking turntable, Ron.  I don't envy you dealing with the NBWs.
Ron you did a great job with the NBW's. You were smart using the Tichy product. Every additional step makes the TT more awesome.
Ron that is outstanding!
Now that you got those little NBW's done sit down have a double scotch and call it a day!!  ;D
Quote from: deemery on August 09, 2026, 10:52:57 AM'Fess up, Ron.  How many NBWs did you lose in this process?  ;D
Only 2 Dave.  ;D  The ones I used had bigger shanks so harder to lose.
Quote from: Larry C on August 09, 2026, 10:54:17 AMRon having to assemble ALL those NBW's would have taken the "hernia size" bottle of Scotch. Great job and it looks terrific; it'll look great when installed.
Thanks Larry, I wanted to keep some of my scotch collection for another day.  ;D
