Pratt's Cove
Started by Larry C, August 29, 2026, 03:13:39 PM
Both floors have been installed. The bottom floor was built on a piece of 100# paper (thin card) using 2x10's grained, colored with chalks & clear alcohol then giver a coat of A&I. Curious I used wood from the same bundle but yet ended up with 3 different variations using the same exact method. On the top floor I made an oops and mis-measured one boards but since it won't show either through the opening or when the roof is on I decided not to worry about it. Also cutting around the 6x6's came out pretty well.
Since I'll be doing water for the Cove I decided I needed something for a solid base and something that would take paint well. To that end I went with a 10x14 inch piece of birch plywood and made sure it was nice and square.
Continuing on:
Thought I'd show how I attach foam to the plywood; this piece was cut from 2 layers of 1/2 inch foam just so it was easier to cut and would have smooth square edges. I add a generous amount of white glue then used a thin non-used credit card and drag it over the top to get a thin layer of glue like I did at the top of the photo. Once applied it sets for a couple of minutes until the glue is tacky then it's applied to the plywood, lined up where I want it, and weighted to let dry; usually it's cured in a couple of hours.
So this will be the basic setup. After finding a suitable piece of pink foam in the garage I cut it to fit under the building and all the way across the back making sure the cuts were smooth and square. The piece of card in the front is where the dock will be going and the piece to the left will be a cabin for the owner to live in. The green foam coming to the front will be, hopefully, for a lighthouse and details. The small pink slanted foam, which I'm going to replace with something more suitable, Is to help break up the straight lines.I did raise the building by using a piece of 1/2 inch green foam so the dock would end up being the right height for the boat. Also the foam was cut to transition from one level to the next.
Speaking of boats, I decided to just extend the length of the boat by 4 scale ft. by adding on to the existing hull then rewrapped the sides; now the proportions look much better. Once all the side wood and deck are added you'll never to be able to tell the boat was extended.
That's where I'm at for the moment. Next up will be to add a sub-roof and then the metal roof for the building over that. Thanks for stopping by and leaving all your great comments and/or suggestions; they really do help.
Larry I'm really interested in your water feature and the before preparations. I have this exact thing in my near future.
Quote from: PRR Modeler on September 10, 2026, 11:50:37 AMLarry I'm really interested in your water feature and the before preparations. I have this exact thing in my near future.
Considering this is only my second serious attempt at doing a water feature hopefully it'll be of some help. Also check out some of Robert Goslin's threads; he does a great job at harbors/water features. I did attempt one on the other forum but I hated the way it came out so I won't make the same mistakes twice.
Howdy Larry,
The new scene is progressing well.  The additional length on the boat will make it more realistic, IMHO.  Judging from your past endeavors, this should be a fun one.  Nice start!
Larry I like the way this is working out.  You're taking time to do it and it shows in your work.
Very nicely done.
Quote from: friscomike on September 10, 2026, 07:28:26 PMHowdy Larry,
Thanks Mike and yes I agree the boat looks much better now.
Quote from: Jerry on September 10, 2026, 10:41:28 PMLarry I like the way this is working out.  You're taking time to do it and it shows in your work.
Very nicely done.
Thank you so much. I'm looking forward to seeing this coming together.
robert goslin
Hi Larry, good that you've been able to lengthen the boat without too much trouble.
Can you tell me how high the hull is, as it looks way too high at the moment, and you still have to add the sides above the deck.  My hulls from waterline to the top of the deck are only about 13 or 14mm.
Regards  Rob
Melbourne,  Australia
Quote from: robert goslin on Today at 02:36:31 AMHi Larry, good that you've been able to lengthen the boat without too much trouble.
Rob mine is 1 inch (about 25.4 mm) so I guess it is way too high. Thanks for pointing that out and I should probably fix that. I'm "flying by the seat of my pants" on the boat building so please feel free to point out my mistakes. I was looking at the thickness when I first cut the hull out and wondered if it was too thick. I should be able to cut another hull from 1/2 inch foam using the same length.
robert goslin
Quote from: Larry C on Today at 07:51:07 AM
Hi Larry.  Yep 1" is way to high.  1/2" (12mm) foam will be good, then add the 1mm deck.
Then when you add the sides, these can be about 10 - 12mm above the deck, so total height will be about 25mm max, plus you make the front portion slightly higher again.
Regards  Rob
