Building the Lost Mine
Started by Jerry, May 31, 2016, 09:37:27 AM
Looking good - I will be following along.
Thank you John good to have you following along.
Morning
The siding is on the back wall.  The left side under the shed roof gets tar papered.
Actually the rest of the building gets tar paper.
I just made a jig for the 7 windows I need to make small tilt out is what the plans call for.
Now that my surgery is done I might be able to make better progress.
Thanks you all for following along.
Afternoon everyone
Here is were the mine stands now the walls are done for the tipple. Not glued together yet as all the wood gets covered with TP.
Comments always welcome.
R Edington
Rodney
Twopoint2
Very nice job on the build so far.
Polux
Wow!! I really like it.
Excellent work so far ;)
Rodney, Jim & Pol.Lux thanks for the compliments and following along.
Here is the first of three bents for the head frame.
The rods still need to be put in. This was the easiest one. The other two have the shaft that sends the cart down the shaft.
Polux
Looks great to me. Excellent work ;)
GaryMc
Very nice, really like the chute detail.
Regards,
Gary
Powersteamguy1790
Nice work Jerry. :)
Thanks guys for looking in on me.  its appreciated.
Working on the second bent now.  Hopefully will have it done by the weeks end.
Once again tank you.
Another update.
The three bents are done on one side they need to be filled in on the two sides facing you. The truss rods are in on these sides.
These are the tracks that lower the bucket and men into the shaft they are made out of .060 x .060 angle and .010 x .040 styrene and sprayed with grimy black.
They will be straight when glue in place in side the bents.
You are moving right along - looking good.
