Burdick's Freight Dock FOS Scale Models
Started by postalkarl, July 18, 2016, 01:08:40 PM
MASIGMON
Karl,
I have been following your Burdick's Build.  I have a few of questions about the paint if you would be kind enough to answer.  I can get Duncan without any problem.  Is there a plus to using the Duncan paints over other craft paints.
When you started the painting process
Light Gray is it Duncan or A & I or Floquil (DRIFTWOOD/GRIME/CN17GRAY)
LIGHT Blue is it Duncan?
White Duncan?
If there is an upside to using Duncan I would like to order the paint & have it ready when I start my build of the kit.  Look forward to your answer
Mike Sigmon
Jacksonville, FL
Polux
Cool!!!
I specially like the colour on the loading dock. Very nice build, Karl ;)
Hi Dave:
Thanks. Yeah I just thought I'd try it and it worked great. Shininess is on underside of roof and can't be seen unless you turn model upside down and look hard.
Hi Mike:
No plus to using Duncan. It was just a different color I had around. I used a combination Of Duncan #OS48 Wedgewood Blue and FolkArt #402 Light Blue.
Where do you get your Duncan paints?
The Gray iis Apple Barrel #20526 Country Gray for dry-brushing. A&I is used over finished paint before dry-brushing.
Hope that helped.
Hi Pollux:
Thanks Loading dock is just dark A&I mix.
Hi All:
Burdick's is finished. here's a final photo. Very fun to build and will be among my FAVORITE FOS KITS.
Polux
That's a clean and tidy build Karl. Very nice ;)
Hi Pollux:
Thanks appreciate you compliment.
Nice little structure, Karl.  The blue came out great.
Hi Jeff:
Thanks appreciate your compliment.
MASIGMON
Karl,
The Freight Dock finish looks perfect.  Very Clean & natural (not rundown) weathering.
The Structure looks very Small Town USA were everything in the little town comes & goes via rail using this little structure
I found Duncan on E-bay.  bargainbobstore offers DUNCAN OSKIT-1 12 colors for $34.74.  If Duncan was the new craft paint that everyone was going to use I was going to order a set to try.
What is your next build going to be
As always looking forward to fit
I do have a question
Before you apply any acrylics to a basswood wall do you prime the wall with a Floquil product such as Driftwood/CN17/Earth or our you using something different these days
Thanks
Mike Sigmon
Jacksonville, FL
Hi Mike:
Naw I don't prime just paint the walls the color I want them. I mostly use hardware store sprays now. Found several good colors. The new build FOS Methias Metal Spring & Wire. See photos under it in Kitbuilding. Used primer white windows, doors and trim. and primer red oxide for walls. Wil;l use the Applebarrel gray for dry-brushing.
I believe Duncan is used by the ceramic artists.
That came out great Karl , blue suits you well  ;)
ger deguelle
